How is momentum conserved in an inelastic collision?
The discussion revolves around the conservation of momentum in inelastic collisions, a topic within the field of mechanics. Participants are exploring why momentum is conserved despite kinetic energy not being conserved in such collisions.
  • Participants discuss the distinction between momentum and kinetic energy, noting that momentum is a vector quantity while kinetic energy is a scalar. There are attempts to clarify the conditions under which momentum is conserved, particularly in the context of collisions where objects may stick together.
Several participants have provided insights into the conservation of momentum, referencing Newton's laws and the vector nature of momentum. There is an ongoing exploration of the implications of external forces and the relationship between forces during collisions. No consensus has been reached, but productive lines of reasoning are being developed.
Participants are grappling with the implications of losing speed in a collision and how that relates to momentum conservation. There is a focus on the definitions and principles of momentum and forces involved in collisions.
II Ziv II
This was a test question that I got wrong and it has been bothering me so much. How is momentum conserved in an inelastic collision?
p = mv
KE = (.5)m(v^2)
I know that kinetic energy is not conserved because some of the energy in the collision escape as heat, sound, etc but why is momentum conserved? Shouldn't the system lose momentum because it it losing speed?
There are a number of ways of approaching this. It depends, among other things, on the fact that momentum is a vector while kinetic energy is a scalar.
Two identical objects with the same speed could collide head in and both come to rest and stick together.
In this case, all the kinetic energy has gone. It's also a perfectly inelastic collision.
The momentum situation is different.
The one object, moving from left to right, has momentum mv, but the other, moving right to left, has momentum -mv.
Momentum before is mv + (- mv) [the vector sum takes account of the direction]
the momentum after is zero. (both at rest)
Before = after (both zero) yet you have "lost speed".
You can also argue for conservation of momentum from Newtons 2nd and 3rd Laws.
Welcome to PF!
Hi II Ziv II! Welcome to PF! :smile:
I think the answer they want in the exam is good ol' https://www.physicsforums.com/library.php?do=view_item&itemid=26" … total force = rate of change of total momentum.
Since there are no external forces on the colliding bodies, the rate of change of total momentum is zero, ie the total momentum is constant. :wink:
Speed? We do not work with speed in momentum, we work with velocity.
p = mv
KE = (.5)m(v^2)
In my view, the best way to explain conservation of momentum is this:
1. [itex]F = dP/dT => dP = Fdt[/itex] (definition)
2. Ball A and ball B collide. The change in momentum of A is the force of B on A multiplied by the time through which it is applied ie. time of contact (I'm over-simplifying - since the force is not constant, you have to take the integral of force x dt) .
3. The change in momentum of B is the force of A on B x time of contact.
4. BUT, the force of A on B is EXACTLY equal to the force of B on A but EXACTLY opposite in direction (Newton's 3rd law). AND, the time through which these forces last is EXACTLY the same for both. So the magnitude of the change in momentum of A is EXACTLY equal to the magnitude of the change of momentum of B and EXACTLY opposite in direction.
AM
  • · Replies 47 ·
  • · Replies 16 ·
