Can Mathematica help with solving projectile motion equations?
  • Context: High School
  • Thread starter Thread starter tempneff
    Mathematica Physics
The discussion revolves around the use of Mathematica for solving projectile motion equations, focusing on syntax and resources for implementation. Participants explore the practicality of using Mathematica versus simpler methods for solving these equations.
  • Technical explanation, Debate/contested, Homework-related
  • One participant expresses a desire to use Mathematica for projectile motion equations and seeks advice on syntax and resources.
  • Another participant questions the necessity of using Mathematica for simple projectile motion problems, suggesting that a handheld calculator might be more efficient.
  • A third participant provides a specific syntax example for defining a function in Mathematica, indicating two possible forms for the equation.
  • A fourth participant references an external resource that contains a detailed example of projectile motion using Mathematica.
Participants do not reach a consensus on the necessity of using Mathematica for simple projectile motion equations, with some advocating for its use while others suggest simpler alternatives.
Some assumptions about the complexity of the projectile motion equations and the user's familiarity with Mathematica are not explicitly stated, which may affect the discussion.
tempneff
I am hoping to use Mathematica to solve simple projectile motion equations. Can anyone offer some tips in regard to the syntax, or maybe a reference guide/site?
Why? If the projectile motion questions are actually simple it will probably take you more time to put it into Mathematica than to use a handheld calculator.
What exactly did you have in mind? It's hard to offer syntax advice when you don't fully explain what you want to do.
Try the online help, it is quite good and is what I use.
x[t_]:=a t^2 + v0 t + x0
or
x==a t^2 + v0 t + x0
depending on if you want an equation or a function.
There is a detailed example of projectile motion using Mathematica at
http://blog.wolfram.com/2010/09/27/do-computers-dumb-down-math-education/"
  • · Replies 60 ·
  • · Replies 25 ·
