Specific Heat Capacity of Diesel Liquid & Gas - J/kgK
  • Thread starter Thread starter Mech_guy
    Diesel Properties
The discussion revolves around the specific heat capacity of diesel fuel in both its liquid and gaseous states, particularly in the context of a heat exchanger report for a domestic boiler. Participants explore the implications of these values for heat transfer and combustion processes.
  • One participant requests the specific heat capacity of diesel in both liquid and combusted gas states, specifying the need for values in J/kgK.
  • Another participant notes the distinction between evaporated diesel and combusted diesel, suggesting clarification on which state is being referenced.
  • A participant mentions that the specific heat capacity of diesel (~1750 J/kg K) may not be relevant for the boiler's operation, as the combustion produces CO2 and H2O, not diesel fuel.
  • It is suggested that the lower heating value (LHV) of diesel fuel is crucial for understanding the heat produced during combustion and its efficiency in heating applications.
  • A participant expresses gratitude for the clarification regarding the exhaust composition and indicates that their system functions as a preheater, acknowledging the complexity of the topic.
Participants do not reach a consensus on the specific heat capacities or the relevance of these values to the boiler's operation. Multiple viewpoints regarding the importance of different properties of diesel and combustion products are presented.
There are unresolved aspects regarding the specific heat capacities of both liquid and combusted diesel, as well as the assumptions made about the combustion process and its efficiency.
Mech_guy
I am doing a heat exchanger report for a domestic boiler, and would anyone know what the specific heat capacity for diesel in its liquid and gas(having been combusted) state. In J/kgK please thanks
There is a big difference between the gaseous form of diesel (evaporated) and combusted diesel. I'm assuming you're looking for evaporated diesel but you should clarify.
Wolfram Alpha has some good info: http://www.wolframalpha.com/input/?...a=*DPClash.CommodityE.diesel-_*NYMEX:LL.dflt-
The diesel is being used to fuel the boiler that heats my house. So to obtain the ideal heat transfer of the gas the exits the exhaust, I would need to know its specific heat capacity. The site you gave me didn't quite yield the results i was looking for, but thank you
I think you're a bit confused about the tools you need to solve this problem. If I'm following you correctly, you are looking at a boiler that runs off of diesel and it is heating water, that in turn, heats your house via steam.
The specific heat capacity (~1750 J/kg K) of the diesel is largely irrelevant to this problem, unless you're designing a preheater to the boiler. The outlet for this side of the boiler does not contain diesel fuel. The diesel is consumed in a reaction, and (for all intents and purposes) CO2 and H2O are produced. The specific heat of that mixture can be found by taking a simple mixture of the gases produced using a combustion equation and something like C12H23 as a decent stand-in for diesel fuel.
If I were looking at this, I'd first want to know the lower heating value (LHV) of the diesel fuel. The LHV is the heat of combustion, minus the vaporization energy of the stoichiometrically produced water. This basically tells you how much heat is produced by the diesel and is available for exchange, assuming 100% efficiency. This value will let you know how much water you are able to vaporize and use to heat your house.
For a quick back of the napkin calculation, you can take the LHV of the diesel and assume an 80% or so thermal efficiency. That's about typical for most process boilers, but it could range from 50-90%, depending on your specific model.
mhmounty,
thanks very much for interoperating my query correctly as i was having a lot of trouble with that aspect. Rather embarrassed actually that it didn't dawn on me that it would be a CO2 and h20 mixture for the exhaust. As it turns out it is in a way a preheater, though you have given me a lot to think about. I may have more questions in the future, if you would oblige.
Thanks
Mech-Guy
10K
