| New Reply |
Heat Exchanger/Heat Sink |
Share Thread | Thread Tools |
| Nov27-10, 11:37 AM | #1 |
Hello Guys,
What is the difference between these two, Heat Exchanger and Heat Sink? Thanks. Zeus |
| Nov27-10, 01:39 PM | #2 |
Mentor
Welcome to PF.
A "heat sink" can be a specific object that dissipates heat (a metal block with fins) or can be used as a general term describing anything that absorbs or dissipates heat. Technically, it is supposed to be a heat reservoir. Depending on the context, the colloquial usage may not be technically accurate. A heat exchanger is any device that exchanges heat between two mediums. For example, in engineering a heat exchanger might be a shell that's filled with water with tubes of another stream of water in it. The water itself (that is receiving the heat) would technically be the heat sink. |
| Nov27-10, 05:09 PM | #3 |
Thanks for reply.
| New Reply |
| Thread Tools | |
Similar Threads for: Heat Exchanger/Heat Sink
| Can this be done with a heat exchanger? | General Engineering | 6 | ||
| Is the overall heat transfer coefficient constant for a certain heat exchanger? | Advanced Physics Homework | 0 | ||
| water cooled heat sink | Electrical Engineering | 4 | ||
| heat exchanger | Materials & Chemical Engineering | 0 | ||
