How do I calculate top velocity for a constant mass rocket in a vacuum?
  • Context: Undergrad
  • Thread starter Thread starter JacksonMarks
    Constant Mass Vacuum
The discussion revolves around calculating the top velocity of a constant mass rocket operating in a vacuum, with a focus on the implications of thrust and mass loss. Participants explore theoretical aspects of rocket motion, including the effects of relativity and fuel consumption, while considering the context of a simplified physics engine for a video game.
  • One participant expresses confusion about calculating top velocity for a rocket with constant mass and thrust in a vacuum, noting the expectation of infinite acceleration.
  • Another participant asserts that without additional forces, the rocket will continue to accelerate indefinitely in a vacuum, contrasting this with atmospheric conditions where drag would limit speed.
  • A follow-up question is raised regarding the impossibility of traveling at the speed of light, linking it to the nature of a vacuum and relativity.
  • Participants discuss the implications of relativity, noting that there is a maximum speed (the speed of light) that cannot be reached, even in a perfect vacuum.
  • Concerns are raised about the assumption of infinite fuel supply, with a participant highlighting that real rockets cannot sustain thrust indefinitely due to fuel consumption and mass loss.
  • A formula for final velocity is presented, emphasizing the importance of mass ejection in achieving thrust, which is often overlooked in simplified models.
  • Another participant reiterates that achieving light speed requires infinite energy, which is feasible in the theoretical setup but not in practical scenarios.
  • One participant acknowledges the importance of fuel consumption but insists that it is not a concern for their arcade game physics engine.
Participants generally agree that a rocket in a vacuum will accelerate indefinitely without external forces, but there is disagreement regarding the implications of fuel consumption and relativity. The discussion remains unresolved on how to incorporate these factors into the physics engine.
Limitations include the assumption of constant mass and thrust without accounting for fuel consumption, as well as the neglect of relativistic effects in a simplified model.
JacksonMarks
I'm programming a simple physics engine that works with rockets in space. I haven't done any physics since high school and I'm embarrassingly lost on how to proceed.
What I have is a constant mass (say 50,000kg for example), and a constant thrust (75,000N for example) on the mass. The mass is in a vacuum. For simplicity, there is no gravity working on the mass either.
How do I calculate the mass' top velocity? I seem to be missing something or not taking something into account because as far as I can see, the mass will accelerate infinitely which I know doesn't make sense.
Any and all help would be appreciated.
Unless some other force acts on the rocket (and ignoring relativity), it will keep going faster and faster! In an atmosphere, drag force would limit the rocket to some maximum speed, because as you go faster the air pushes back on you harder and harder, until it cancels out your thrust. In a vacuum there's no such drag.
If that is true, then why is it considered impossible to travel at the speed of light? Or is that due to the fact that space is in fact not a perfect vacuum?
This is why I added the caveat about relativity. In special relativity there is an absolute maximum speed which is the speed of light, even in a perfect vacuum. But I doubt you want to include relativistic effects (which would in any case be very small unless your ships will be traveling monstrously fast) in a simple physics engine.
You're not taking into account the fact that you don't actually have an infinite supply of fuel so you can't sustain that thrust forever.
You should also probably consider that burning fuel decreases the mass of the rocket
Ah alright. Thank you very much for your quick responses.
I'm aware of both those facts but it's not something that is important for my case.
But that IS part of why a real rocket can't reach velocities anywhere close to speed of light. If we could build rockets that can sustain constant thrust without loosing mass, we'd be colonizing other stars by now.
Real rocket creates thrust by ejecting mass at some fairly constant speed Vp. If the fueled rocket had mass mi, and once it ejected all its propellant it has mass mf, then the final velocity is given by the rocket formula.
[tex]V = V_p ln\left(\frac{m_i}{m_f}\right)[/tex]
If you ignore this in your simulation, you are effectively using infinite Vp, and then you shouldn't be surprised that your top velocity is also infinite.
Also, for an object with mass to reach light speed, you need an infinite amount of energy, feasible with your setup but not in reality.
I appreciate that rockets in real life are fuel based and that they must expel mass in order to actually achieve thrust, but this physics engine is just for a simple arcade video game and as a result players are not going to be restricted on fuel.
  • · Replies 26 ·
  • · Replies 46 ·
  • · Replies 17 ·
  • · Replies 131 ·
9K
  • · Replies 27 ·
  • · Replies 35 ·
