Pendulum problem only the rope breaks
  • Thread starter Thread starter drmumma
    Pendulum Rope
The problem involves a pendulum scenario where a person swings on a swing, and the rope breaks when he is near the ground. The parameters include the height above ground, the length of the rope, the mass of the person, and the angle of the swing. Participants are exploring how to determine the distance the person will land from the point of release.
  • Participants discuss the relationship between radians and degrees, the use of conservation of energy to find velocity, and the potential application of equations of motion. There is also mention of using arc length and whether it is necessary for the problem.
The discussion is active, with participants offering various approaches to the problem, including conservation of energy and projectile motion. There is no explicit consensus on the best method, and multiple interpretations of the problem are being explored.
Some participants express confusion about the necessary equations and concepts, indicating a lack of clarity on how to proceed with the problem. There is also a mention of constraints related to the resources available for finding a solution.
drmumma
Alrighty this problem is making me crazy.
A guy is swinging on a swing where the height above ground=2ft., the length of rope=8ft., mass of guy=100kg and theta=30 degrees. The rope breaks when he is close to the ground... what is the distance that he will land on the ground?
I am so lost, I don't even have a solution in 3 physics books I have...
Do we need arc length at all and convert it to radians... possibly find acceleration?
Ok, so what's the relation between radians and degrees? ( I prefer radians because they are used as standard measure...you can do it with degree measure too.)
And then find the max height to which the swing rises, use conservation of energy to find the velocity at the instant the man drops from the swing. Then solve using equations of motion.
You are my hero! ok awesome so find acceleration via conservation of energy then use perhaps a physical pendulum equation? or simple pendulum equation?
drmumma said:
so find acceleration via conservation of energy?
no, velocity when the man leaves the swing.
no, read my above post carefully.
Use the projectile and linear motion equations.
