Linear Algebra proof with Linear Transformations
The discussion revolves around a proof involving a real symmetric n × n matrix A and its relationship with subspaces in R^n, specifically focusing on the containment of A(V perp) within V perp given that A(V) is contained in V.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants explore the definitions of V and its orthogonal complement V perp, questioning the implications of vectors belonging to these spaces. There is an attempt to clarify what it means for a vector to be in V perp and how that relates to the transformation by A.
The discussion is ongoing with participants seeking definitions and clarifications about the properties of orthogonal complements and the implications of the linear transformation A. Some participants are attempting to connect the concepts of inner products and kernel spaces to the problem at hand.
There appears to be confusion regarding the definitions and properties of V and V perp, as well as how to relate these to the matrix A. Participants are encouraged to clarify foundational concepts before proceeding with the proof.
CDrappi
Suppose that A is a real symmetric n × n matrix. Show that if V is
a subspace of R^n and that A(V) is contained in V , then A(V perp) is contained in V perp.
A = A_T (A is equal to its transpose)
I have no idea where to start
Take a vector [tex]v\in V^\bot[/tex] (what does this mean??).
You'll need to show that [tex]Av\in V^\bot[/tex] (what do you need to show for that?)
I still am not sure what to do. Any further helpings?
What does [tex]v\in V^\bot[/tex] mean??
What does [tex]Av\in V^\bot[/tex] mean??
Just give the definition...
That a vector v is contained in V perp
That a vector Av is contained in V perp
Yes, of course. But what does it mean that v is contained in [tex]V^\perp[/tex]. What property must hold?
If V = C(B), the column space of some matrix B, then Bv = 0
Hmm, how did you define [tex]V^\bot[/tex]? I remember that it had to do with inner products...
Wouldn't [tex]V^\bot[/tex] just be the left nullspace of B?
Yes, but if you're given a set [tex]V^\bot[/tex]. How do you find the matrix B??
I do not know. Help prease!
Given a subspace V. How did your course define the subspace [tex]V^\bot[/tex]??
For a subspace V spanned by the column space of a matrix V, Ker(VT) returns [tex]V^\bot[/tex] (orthogonal complement to V). If v is in V and vp is in the orthogonal complement, then vp is in Ker(VT). Avp should also be in Ker(VT). If it is, then the inner product of Avp and v should be 0.
Oh. We defined it as whatever part of R^n that V isn't in
Gear300 said:
For a subspace V spanned by the column space of a matrix V, the Ker(VT) returns [tex]V^\bot[/tex].
Can you write the last part of that out to make it a little clearer? I can't understand exactly what you mean.
hmph. it seems you've edited it on me
  • · Replies 24 ·
  • · Replies 26 ·
