Resistor Shorting and Kirchhoff's Rule Explanation
  • Thread starter Thread starter member 217843
    Resistor
The discussion centers on the application of Kirchhoff's Rule in analyzing a circuit where an 18 Ω resistor is shorted out, effectively reducing its resistance to 0 Ω. The participant initially excluded the shorted resistor from calculations, leading to confusion regarding the correct current I1. Ultimately, the correct approach involves including the shorted resistor in the analysis, as it influences the overall circuit behavior despite its resistance being zero.
  • Understanding of Kirchhoff's Voltage and Current Laws
  • Basic knowledge of electrical resistance and Ohm's Law
  • Familiarity with circuit analysis techniques
  • Ability to interpret circuit diagrams
  • Study Kirchhoff's Voltage Law (KVL) and its applications in circuit analysis
  • Explore the concept of short circuits and their effects on current flow
  • Learn about series and parallel resistor combinations
  • Investigate practical examples of circuit analysis involving shorted components
Electrical engineering students, circuit designers, and anyone looking to deepen their understanding of circuit analysis and the implications of shorted components in electrical circuits.
member 217843
What would the current I1 be in the figure below if the 18 Ω resistor is shorted out (resistance = 0)? Let r = 1.0 Ω.
I used Kirchhoff's Rule
I figured this problem out, but I had trouble, and I'm not sure I understand why the answer is what it is. I'm confused about the resistor shorting out. At first, I wrote out the problem not including the shorted out resistor, as the resistance became 0 when it shorted out. However, this was wrong. I then attempted the problem including the 18 ohm resistor, and I got the correct answer.
Can someone explain to me why you need to include the shorted out resistor?
Note: I simply want to understand why, I don't need the problem worked out, as I already found the numerical answer.
You had it right the first time. If the resistor is shorted, it should not be included in the calculations. It sounds like the solutions you were given might be incorrect.
  • · Replies 18 ·
