Build a Roller Coaster: Tips for 2 Loops & 2 Hills
The discussion centers on a physics project requiring the construction of a roller coaster for a golf ball using recycled materials, specifically needing two loops and two hills. The primary challenge is achieving a second hill with a minimum displacement of 20 cm, as the initial design fails to provide enough height after the first hill. Participants emphasize the importance of converting kinetic energy (KE) to potential energy (PE) to facilitate the necessary elevation for the second hill, while also addressing the need for effective materials that can support the structure without prefabricated components.
  • Understanding of kinetic energy (KE) and potential energy (PE) concepts
  • Basic principles of physics related to motion and energy transfer
  • Familiarity with construction techniques using recycled materials
  • Knowledge of roller coaster design principles, particularly for small-scale models
  • Research effective materials for building roller coaster hills, focusing on lightweight and sturdy options
  • Explore advanced roller coaster design techniques, including energy conservation methods
  • Learn about the physics of loops in roller coasters and how to optimize them for small-scale models
  • Investigate methods for reducing friction in roller coaster designs to improve performance
This discussion is beneficial for students in physics classes, educators looking for hands-on project ideas, and hobbyists interested in engineering and design principles related to roller coasters.
Chem4Life
So my physics class (No, it's not homework, per se, so I didn't put it in that section) decided we were going to build roller coasters. (Basically, it's a big pain. I wish we hadn't.)
Anyway, here are the rules:
Has to be for a golf ball, made out of recycled materials. This also means no materials for construction (but chicken wire is allowed, and I used it for my first hill.. The second hill just didn't work..), and no prefabricated materials (Legos, Kenex, etc)
2 loops, 2 hills.
Loops: Obviously, just have to have vertical displacement. I've got those down pretty well. They work, anyway.
Hills: Have to have a minimum 20 cm displacement. This is the problem..
I've got the first hill and loop, but now that I'm on the second hill, I'm on the ground (because I started at a certain height, and you have to go down, obviously..) and I can't make it go back up. We tried putting it on boxes, and making the incline longer and more sharp, but nothing's worked..
Any suggestions for how to make it work or better things to make the second hill out of? Boxes and Chicken Wire just aren't cutting it at this point..
2 loops, 2 hills.
Welcome to the PF.
It's still schoolwork, so it belongs in the Homework Help forums. I've moved it for you.
What exactly are the rules of this project? You understand that KE and PE trade off, right? So just because you are at ground level, doesn't mean that you can't climb back up a rise trading off some of your KE for PE. You also have rotational KE in your golf ball as it rolls along...
Well, the hill sort of works at this point. It almost stops at the end, and when it goes back down, it speeds up well enough.. We're just altering it, because now the second loop just can't go around. We're changing loop materials, but yes, the concept is grasped, I suppose you could say. The execution is a bit.. complicated.
Oh, the worst part, besides the building is that, to get extra credit the 2nd loop has to be at the end, and the golf ball then has to roll to a stop without friction or anything cushioning or sticky, and stop within an inch of an egg. It can touch the egg, but can't crack it.
  • · Replies 16 ·
19K
