Physical Pendulum Question for Moment of Inertia
The discussion revolves around calculating the moment of inertia for a physical pendulum consisting of a thin rod and a spherical bob. Participants are addressing multiple aspects of the problem, including the center of mass, net torque, angular frequency of oscillations, and specifically how to correctly apply the moment of inertia equations for both the rod and the bob about the pivot point.
  • Homework-related
  • One participant has calculated the center of mass as 0.605 m but is uncertain about how to set up the moment of inertia for the rod and the bob.
  • Another participant suggests that the moment of inertia of the rod and bob about the pivot is the sum of their individual moments of inertia calculated about that point.
  • There is a discussion about using the parallel axis theorem to find the moment of inertia of the rod about the pivot, with references to the inertia of the rod about its center and the distance to the pivot.
  • Some participants express confusion regarding the application of the parallel axis theorem and whether their formulations for the moment of inertia are correct.
  • There is a reiteration of the formula for the moment of inertia of a point mass and its application to the spherical bob.
Participants do not reach a consensus on the correct formulation for the moment of inertia, with ongoing confusion and differing interpretations of the parallel axis theorem and its application to the rod and bob.
Participants reference various equations for the moment of inertia but do not clarify all assumptions or definitions, leading to potential misunderstandings about the distances involved and the application of the parallel axis theorem.
AdanSpirus
Ok So here's my question.
The physical Pendulum consists of a thin rod of mass m = 100 g and length 80 cm, and a spherical bob of mass M = 500 g and radius R = 25 cm. There a pivot P at the top of the rod.
(Sorry, I don't have a picture >.<)
a) It asks for the center of mass(I already got it)
b) It asks for the moment of Inertia
c)Calculate Net Torque
d) Find Angular Freq. of small oscillations
e) At t= 0, the pendulum position is theta = (theta)max / 2, where (theta)max is the amplitude , and theta is increasing. When is the next instance where the particle will have a speed that is one third of its maximum?
I = Icm + Md^2
Sphere = 2/5MR^2
Rod = 1/2MR^2
Rcm = (m*l + M(R+l)/(m+M)
s = Acos(wt + phi)
v = -wAsin(wt + phi)
a = -w^2Asin(wt+ phi)
I have got the center of mass which results to be 0.605 m.
The only problem I have is that I am not sure about the moment of Inertia considering there are 2 objects and I am not exactly sure of how to set up the moment of inertia equation with the Sphere and the Rod. This is what is only bugging me atm, I probably can do the rest if I figure out the moment of inertia >.< But I might post back after if I don't get the rest of the question.
The moment of inertia of the rod+bob about the pivot would just the sum of the moments of inertia of the rod and bob about the point P
AdanSpirus said:
I = Icm + Md^2
Sphere = 2/5MR^2
Rod = 1/2MR^2
Rod should be (1/12)ML2
Since the sphere will not be rotating you can consider it as a point mass such that the distance of its center to P is (L+R).
moment of ineria of a point mass = mass*distance2
So is the moment of Inertia then I = 1/12ml^2 + M(R+l)^2 ?
For the rod rotating about its own center the inertia is (1/12)ML2, so to get it about P, you need to use the parallel axis theorem.
The inertia for the bob about P is correct as M(R+L)2
I still don't understand >.<
Since the Parallel Axis Theorem states that its I = I(center of mass) + Md^2, so wouldn't my statement be correct?
I = (1/12)ml^2 + M(L+R)^2?
Ibob/SUB] (about P) = M(L+R)2
Irod(about its center)=(1/12)ML2
You need to apply the parallel axis theorem for the rod to get it about P.
Uhhmmmm so is that what I said? I = (1/12)ML^2 + M(L+R)^2?
Because the parallel axis theorem is the following equation:I = Icm + Md^2
No, what you are doing is adding (the moment of inertia of rod about its own center) + (moment of inertia of the sphere about P).
You need to get the the moment of inertia of rod about P.
For the rod, Icenter=(1/12)ML2
and P is at L/2 from the center.
9K
  • · Replies 21 ·
