Has anyone studying electrical eng. had the class Linear Circuits ?
The discussion centers on the course "Linear Circuits" within electrical engineering, emphasizing its focus on linear systems characterized by bounded-input bounded-output (BIBO) stability. Linear circuits simplify calculations and enable the application of algebraic transformations, matrix math, and circuit analysis techniques such as Thevenin and Norton reductions. Non-linear systems, which complicate analysis and calculations, are not covered in this course. The importance of linearity in engineering is highlighted, as it allows for predictable and manageable circuit behavior.
  • Understanding of linear systems and their properties
  • Familiarity with algebraic transformations in circuit analysis
  • Knowledge of Thevenin and Norton theorems
  • Basic concepts of Fourier, Laplace, and Z-transforms
  • Study the principles of bounded-input bounded-output (BIBO) stability
  • Learn about Thevenin and Norton circuit analysis techniques
  • Explore Fourier and Laplace transforms in the context of linear systems
  • Investigate the implications of non-linear systems in circuit design
Electrical engineering students, circuit designers, and professionals involved in analog circuit analysis and design will benefit from this discussion.
land_of_ice
Has anyone studying electrical eng. had the class " Linear Circuits "?
what is this about, and why is it not called for example, something other than linear? in math , there is a lot of things that are not linear , so why do they call the class linear circuits?
Basically it deals with "linear systems", or systems that are bounded-input bounded-output (BIBO) stable. Non-linear systems are not discussed because it becomes much more involved, and most basic circuits exhibit linear characteristics.
Ah yes, linear. Here's the thing. If you can assume some system or circuit is linear, all sorts of calculations become easier. In some cases, calculation simply become possible (vs. impossible). Since engineers deal in the possible, this is important.
The reason comes from your high school algebra calls: distributed law applies with linear networks or systems. This means you can do algebraic transformations like: ab+ac = a(b+c). Or for an EE doing a KVL loop: Vcc - IR1 + IR2 = Vcc - I (R1+R2) = 0 . Another example is cascading amplifiers. If they are linear, you can say Asystem = A1 * A2 * A3 for all frequency components when you cascade them. If they are nonlinear, you can't say that. See IMD/THD below.
For example, matrix math instantly applies. You can do things like Thevenin/Norton reductions and general analog circuit analysis strictly if and only if things are linear.
The opposite is, of course, non-linear. This all gets back to polynomials and Taylor expansions. Being linear means you can truncate the Taylor expansion representation of a nonlinear system without too much error. In fact, audio equipment specs like IMD and THD are nothing more than measures of that truncation error.
You also get more complex math available like Fourier, Laplace and Z-transforms if things are linear. This is usually part of "Linear Systems" vs. "Linear Circuits" which is analog circuits. For example, in the IC industry, analog IC circuits == linear circuits.
So you can think of a large part of engineering school as figuring out how to keep things linear (and predictable) rather than nonlinear and less predictable.
It's not just EE that used linearity like this - 1st order statics in ME do the same thing for the same reasons.
9K
