Register to reply
Partial pressure and liquid water
by jf22901
Tags: liquid, partial, pressure, water
Share this thread:
jf22901
#1
Dec5-10, 06:39 PM
P: 55
Hi everyone
I'm reading up on the possibility of liquid water existing on the surface of Mars, and have confused myself!
During my reading, I have come across various definitions that say liquid water can exist if the temperature is above 273 K and the atmospheric pressure is above 611 Pa, but others say it is the partial pressure of water vapour that needs to be above 611 Pa.
As an example, say there is an ice deposit on Mars in a region where the atmospheric pressure is 1000 Pa, and the temperature increases from 270 K to 280 K. What happens in this case? Does the ice turn to liquid or sublime to vapour? The temperature and atmospheric pressure are high enough for liquid water to exist, but how does the partial pressure of water vapour come into things in this situation?
I must be missing something blindingly obvious, but I can't see what it is!
Thanks,
Jack
Phys.Org News Partner Physics news on Phys.org
On-chip topological light: First measurements of transmission and delay
A two-stage trap for single protons leads to measurement of their magnetic properties
Unexpected phenomenon discovered at the surface of a transition metal oxide material
Mapes
#2
Dec6-10, 07:10 AM
Sci Advisor
HW Helper
PF Gold
Mapes's Avatar
P: 2,532
Quote Quote by jf22901 View Post
The second statement is correct. Condensed matter (solid or liquid) will sublimate or evaporate if the vapor pressure is higher than the partial pressure in the gas phase. The vapor pressure of water at 273 K is 611 Pa, so any liquid water would evaporate unless the partial pressure of water vapor in the gas phase were at least 611 Pa.
The ice will sublimate into vapor. See the phase diagram here, keeping in mind that the pressure is that of the water vapor, not the total pressure.
Also, if the original atmospheric pressure (at 270 K) did not include at least ~600 Pa of water vapor partial pressure, the ice would be sublimating already. Does this make sense?
jf22901
#3
Dec6-10, 02:01 PM
P: 55
Quote Quote by Mapes View Post
Hi Mapes
Thanks for the reply. I think it makes sense now, but let me just try another example to make sure I have actually understood it! It's strange that I am comfortable with what what might be classed as 'difficult' physics topics (such as quantum mechanics, electromagnetism, calculus of variations etc.), but thermodynamics confuses the heck out of me!
Right... lets say there is a block of ice on Mars, the pressure of the atmosphere is 106 Pa, and the temperature rises from 200 - 350 K (in no way realistic, but it'll do as an example, as it is easier to follow on the phase diagram!). Lets also assume the partial pressure due to water vapour in the atmosphere is less than 611 Pa. In this case, although the total atmospheric pressure falls above the triple point, because the partial pressure is below, the ice will sublime directly to vapour as the temperature increases.
But, as the vapour enters the atmosphere, the atmosphere (at least the thin layer close to the block of ice) will become more saturated with vapour, and in this small layer, the partial pressure of the water vapour may increase to above 611 Pa. In such a situation, with the temperature above 273 K (but below the boiling temperature), and the partial pressure due to vapour now above 611 Pa, would the ice begin to melt rather than sublime?
And if it did melt, the liquid would be stable against freezing and boiling, but not necessarily evaporation, unless the air was completely saturated with water vapour?
Thanks once again,
Jack
Mapes
#4
Dec7-10, 08:07 AM
Sci Advisor
HW Helper
PF Gold
Mapes's Avatar
P: 2,532
Yes, this reasoning looks good.
Register to reply
Related Discussions
Why liquid boils when the envrionmental pressure equals its saturated vapor pressure General Physics 4
Liquid pressure General Physics 1
Vapor pressure vs liquid pressure in enthalpic combustion reaction Biology, Chemistry & Other Homework 0
How to count molecules and determine density, partial pressure and total pressure? Biology, Chemistry & Other Homework 0
Liquid under pressure General Physics 8
