Calculating Voltage Across R and C in Series
  • Thread starter Thread starter themonk
    Series Voltage
The discussion focuses on calculating the voltage across a resistor (R) and capacitor (C) in series connected to an AC voltage source. Given values include R = 3 kΩ, C = 100 pF, V_{C0} = 100 mV, and angular frequency ω = 10^5 rad/s. The correct formula to use is V_{R} = (V_{C0} * R) / (1 / (C * ω)). The final calculated voltage across the resistor was determined to be 3 mV after correcting the capacitance conversion error from 100 pF to 1E-10 F.
  • Understanding of AC circuit theory
  • Familiarity with Ohm's Law
  • Knowledge of capacitive reactance
  • Ability to perform unit conversions in electrical calculations
  • Study the relationship between voltage, current, and impedance in AC circuits
  • Learn about the concept of reactance in capacitors and inductors
  • Explore the use of phasors in AC circuit analysis
  • Practice solving problems involving series and parallel RLC circuits
Students studying electrical engineering, circuit designers, and anyone interested in understanding AC circuit behavior involving resistors and capacitors.
themonk
A resistor with resistance R and a capacitor with capacitance C are connected in series to an AC voltage source. The time-dependent voltage across the capacitor is given by V[tex]_{C}[/tex](t) = V[tex]_{C_0}[/tex] sin([tex]\omega[/tex]*t). (there are no superscripts, but they show up as super for me, though I wanted them to be subscripts)
If R=3 k Ohms , C=100 pF, V[tex]_{C0}[/tex]=100 mV, and angular frequency [tex]{\omega}[/tex]= 10^5 rad/s, what is V[tex]_{R}[/tex]?
[tex]\frac{V_{C_{0}}{\cdot}R}{\frac{1}{C{\cdot}{\omega}}}[/tex]
So I plugged in the variables with 3 k Ohms being 3000 [tex]\frac{m^{2}*kg}{s*C^{2}}[/tex], 100 pF being 1E-9 [tex]\frac{s^{2}*C^{2}}{m^{2}*kg}[/tex], 100 mV being 1 [tex]\frac{m^{2}*kg}{C*s^{2}}[/tex] and 10[tex]^{5}[/tex].
When I plugged it all into the equation I got .03 V which is 30 mV*rad. So first there was the problem of the radians being there there is no information about changing it into meters or other useful information. Do I need to use a trig function perhaps?
The hint I was given was : Use the equation obtained in Part B (the equation above) to work out the answer. Be careful of powers of ten in your calculation.
Thank you
hi themonk! :smile:
(have an omega: ω and try using the X2 icon just above the Reply box :wink:)
mmm … you really like breaking down your https://www.physicsforums.com/library.php?do=view_item&itemid=101", don't you? :smile:
radian is dimensionless (metre metre-1) …
you can just multiply any unit by it, and the result is in the same units
for example, if an object moves with position x = rcosωt, y = rsinωt, its velocity is (-ωrsinωt, ωrcosωt), which looks as if it is in units of metre radians per second, but is in fact only metres per second :wink:
Thanks tiny-tim for your advice and help! In the end I had converted 100 pF to 1E-9 F rather than 1E-10 so my answer was off by one degree (30 mV vs 3 mV). And I thought the radians would "disappear" somehow, so thanks again.
  • · Replies 21 ·
