Can a PC Processor Really Be Used as a Heater?
Using a PC processor as a heater is feasible, as nearly all energy consumed by a PC is converted to heat. A typical gaming PC can generate between 100 to 300 watts, while electric space heaters operate at 800 watts on low and 1500 watts on high. Although a PC can provide supplemental heating, it is only effective at 1/8th to 1/3rd the capacity of a dedicated space heater. Therefore, while a PC can contribute to heating a home, it is not a primary heating solution.
  • Understanding of PC power consumption and heat generation
  • Familiarity with thermodynamics principles
  • Knowledge of electrical measurement tools like Kill A Watt
  • Basic concepts of heating efficiency in appliances
  • Research the energy consumption of different PC components
  • Learn about thermodynamic efficiency in computing devices
  • Explore comparisons between PC heating and electric space heaters
  • Investigate the use of energy monitoring devices for home appliances
This discussion is beneficial for tech enthusiasts, energy efficiency advocates, and anyone interested in alternative heating solutions using computing hardware.
todo
Can we use heat from processor for heater?
In some web, they said that is not feasible to do because the heat is not enough.
PC processor has temperature 90 deg C (for game PC),so that is feasible, isn,t?
Looking at the CPU temperature is the wrong approach. A much easier approach is to just realize that virtually every joule that goes into a PC ends up as heat in your house. PC power usage will vary pretty widely. However, 100-300 watts for PC + monitor is probably reasonable. For comparison, most electric space heaters run at 800 watts on low, 1500 watts on high. If you want to measure your PC's usage you can use a device like a Kill a watt, or you can just go outside and look at how much faster it makes your meter spin.
So the answer is, yes a PC will heat up your home. But, it will do it 1/8th to 1/3rd as much as a space heater on low. If you only needed a little extra heat, a PC certainly would work. Plus, it would have the added benefit of doing something useful with those extra CPU cycles.
Thermodynamically, a PC processor is a heater. But they only put out 150W or so. In an office building, computers do a lot of heating - in houses, not all that much.
  • · Replies 30 ·
  • · Replies 67 ·
  • · Replies 32 ·
14K
