Formula for calculating current and or voltage in a coil
The discussion revolves around the calculation of voltage and current in a coil, specifically focusing on a coil of 2 meters in length with certain specifications and the effects of a cylindrical magnet moving through it. Participants explore the principles of electromagnetic induction, resistance, and the characteristics of the coil and magnet.
  • One participant inquires about a formula for calculating voltage and current in a specific coil setup, providing details about the coil's dimensions and resistance.
  • Another participant states that voltage is zero unless the magnet is moving relative to the coil, emphasizing the need to know the rate of change of magnetic flux.
  • A participant questions the concept of magnetic flux and seeks clarification on how to measure or estimate it, suggesting the idea of a magnet dropping through the coil.
  • Discussion arises about the induced voltage in a long coil, with a participant noting that voltage is only noticeable at the ends due to rapid changes in coupled flux.
  • Participants debate the expected voltage generated when the magnet enters and exits the coil, speculating on possible values.
  • One participant explains that current is primarily determined by supply voltage and resistance, and mentions the self-inductance of the coil, suggesting a reference for further calculations.
  • Concerns are raised about the experimental setup, particularly regarding the nature of the magnet and its poles, with suggestions that the configuration may not generate significant emf.
  • Another participant suggests that a cylindrical magnet with axial magnetization would behave differently and could find equilibrium in the center of the coil.
  • A separate inquiry is made about calculating energy loss in a solenoid due to resistance and heat, along with questions about the impact of wire diameter on resistance and solenoid performance.
  • A participant expresses interest in discussing a different configuration for an inductance coil and asks about sharing a visual representation.
Participants express multiple competing views regarding the effectiveness of the experimental setup, the nature of the magnet, and the calculations involved. The discussion remains unresolved with no clear consensus on the best approach or expected outcomes.
Participants highlight limitations in understanding the experimental setup, including the definitions of the magnet's shape and orientation, as well as the assumptions regarding the coil's characteristics and the conditions under which voltage is induced.
Swifters
Is there a formula for calculating the voltage and or current in a 2 meter length of coil? The coil being 30mm in diameter with 1mm thick wire coiled around 200 times (for ease of calculation so cable would roughly be 18.8m long) with a resistance of say 16 ohms. Magnet being a cylindrical sphere of just under 30mm diameter... This is not homework, just wondered if there was a formula? many thanks.
It's zero, unless the magnet is moving relative to the coil, in which case, you'd need to know the rate of change of magnetic flux which will give you voltage in the coil.
Magnetic flux? Is that the strength of the magnet? How could I go about measuring or estimating this? I was thinking of the magnet dropping down through the coil.
For a long coil one will not notice an induced voltage; only at the ends, because then the coupled flux changes rapidly.
So it will only generate a voltage beween entering and exiting the tube? Roughly what are you looking at? 0.01v or 20v?
The current will be dominantly determined by the supply voltage U and the resistance R; it will rise to U/R in less than 1 millisecond being self inductace L over R; the self inductance can be determined with a book, Grover Inductance Calculations. So your supply voltage is the key. I expect 0.5 ohm as resistance and not the value you gave.
The induced voltage determination requires at least that that you know the speed of the magnet and its dimensions. What is a cylindrical sphere, a cylinder or a ball? And when the speed is determined by the force due to the coil, I advice you to contact a electromechanical specialist, capable to calculate this force, e.g. by using a paper from H.Haas in Archiv fuer Elektrotechnik (date about 1980). In the mean time I presume that the magnetization direction of the magnet is in line with the coil axes.
I don't think this is a sound experiment.
1) you have a ball magnet, where are the poles?
2) If you are looking for the emf generated by rolling the ball through the tube, not only the velocity is important, also
3) how do you roll the ball regarding to the poles, the poles can roll in any direction and is not consistance at all.
But I have a suspicion that you are not going to generate any emf because think of a case where the ball rotate on the pole axis( pole axis perpendicular to coil axis), then any given time, one side of the coil see consistent N and the other consistent S, so they cancel. So is if the ball roll with the pole axis rolling along the coil axis, so the coil see alternate N and S and balance out...or almost. You might get a little voltage as the magnet ball enter or exit the coil tube.
You need to have a cylindrical magnet with poles at the ends, then you are talking. Still depend of the total magnetic dipole moment of the magnetic and the speed it travel down.
A cylindrical magnet with axial magnetisation oriented according the aes of the coil will fiinally find an equilibrium in the centre of the coil.
Sorry to bring this up again but is there any way of telling how much energy a solenoid will use for a lateral solenoid for a given length and diameter. Is there an online calculator?
I'm interested to know how much energy is lost in the form of resistance/heat as my understanding of how they work is that they are basically a dead short in a coil? If you increase the diameter of the wire I know resistance will drop but I imagine this will impact on the speed/strength of the solenoid? Thanks
Hi, I am investigating a different configuration for an inductance coil, is there a way I can send a pic here to explain?
  • · Replies 17 ·
  • · Replies 27 ·
  • · Replies 37 ·
  • · Replies 26 ·
22K
