Acceleration, thrust, and propellant velocity?
The average acceleration until burnout of a spacecraft engine producing 53.2 MN of thrust with a propellant velocity of 4.78 km/s can be calculated using the mass flow rate and the change in mass. The initial mass is 2.12 x 106 kg, and the final mass is 7.04 x 104 kg. The average acceleration formula is aavg = Δv/Δt, requiring the determination of the time to burnout and the change in velocity through integration. The thrust-to-mass ratio and the rate of mass ejection are critical for solving this problem.
  • Understanding of Newton's second law of motion
  • Familiarity with rocket propulsion principles
  • Knowledge of calculus for integration
  • Ability to apply conservation of momentum in dynamic systems
  • Calculate the mass flow rate (dm/dt) for the spacecraft engine
  • Determine the time to burnout using the mass flow rate
  • Learn about integrating acceleration to find change in velocity
  • Explore thrust-to-weight ratio calculations for spacecraft
Aerospace engineers, physics students, and anyone involved in spacecraft design and propulsion systems will benefit from this discussion.
camdickman
What is the average acceleration until burnout of a spacecraft engine creating 53.2MN of thrust with a propellant velocity of 4.78km/s? The initial mass is 2.12x10^6 kg and final ,*** is 7.04x10^4.
0 = m(subscript_f)v(_f) + m(_r)v(_r)
0 = (2.12x10^6 - 7.04x10^4)*(4.78x10^3)
v(_r) = 139,163m/s
The problem is, I don't know where to go from here in order to determine the average velocity from here... Help!
v(_r) = 139,163m/s
Start with:
[tex]a_{avg} = \frac{\Delta v}{\Delta t}[/tex]
So you have to find the change in velocity and the time until burnout. Find the time to burnout first and then find the change in velocity.
In order to do this, you have to find the rate at which mass is being ejected: dm/dt, which is constant. Since you know the total change in mass you can easily determine the time to burnout.
The change in velocity of the rocket is a little more difficult to work out. You have to do an integration.
Hint: dp/dt = F = ma = constant = 53.2 MN
[itex]m = m_0 - (dm/dt)t[/itex]
[itex]\Delta v = \int_0^t dv = \int_0^t a dt[/itex]
AM
  • · Replies 26 ·
  • · Replies 62 ·
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 42 ·
