New Reply
Extracting yaw, pitch, roll from transformation matrix
Share Thread Thread Tools
Dec8-10, 10:34 AM   #1
There are two references frames, A and B.
Let A's reference frame be denoted by the columns of the identity matrix, and let A's origin be (0,0,0).
Let B's reference frame and origin be denoted by a transformation matrix T, where T =
R11 R12 R13 x
R21 R22 R23 y
R31 R32 R33 z
0 0 0 1
(Sorry, I don't know how to make it fancy as this is my first post). So basically the R sub matrix is the rotation matrix, and x,y,z is the translation of the origin.
Now, I have the values of the elements of T. From this, how do I determine the yaw, pitch, and roll? Roll is defined to be the rotation about the x-axis; pitch is defined to be the rotation about the y-axis; and yaw is defined to be the rotation about the z-axis.
EDIT:
I have already seen this http://en.wikipedia.org/wiki/Rotatio...eral_rotations and know that I can just set R_x(gamma) * R_y(beta) * R_z(\alpha) * (a column of the R matrix) = <1,0,0> and then solve for gamma, beta, and alpha, but I was wondering if there was an easier, more direct way.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Dec8-10, 12:28 PM   #2
Perhaps look up "Euler angles"
Dec8-10, 01:06 PM   #3
D H
Mentor
A couple of warnings:
1. Note that a roll-pitch-yaw sequence is not the same as a yaw-pitch-roll sequence. There are 12 such Euler sequences: The six aeronautic sequences, the standard Euler sequence (z-x-z), plus five others similar to z-x-z (z-y-z, x-y-z, ...). When you are communicating with others you had dang well better agree on a sequence.
2. You will have to worry about (near) gimbal lock versus non-gimbal lock situations. Gimbal lock occurs when the middle angle of the sequence pitch in a roll-pitch-yaw sequence is 0 or 180 degrees. Near gimbal lock is when that angle is close to 0 or 180. You need to treat those cases specially.
Going from an Euler sequence to a transformation matrix is simple. Going from a matrix to a sequence is not so simple.
Dec8-10, 04:08 PM   #4
This kind of conversion is rather ugly... a nice algorithm that handles all possible configurations of axes (including roll-pitch-yaw) very compactly is given here:
http://etclab.mie.utoronto.ca/people...GEMS/GEMS.html
Dec8-10, 04:27 PM   #5
D H
Mentor
Quote by monea83 View Post
I didn't say how to implement it. Whether you want to do something compact as is done in the reference or a slew of separate algorithms is somewhat orthogonal to the basic issue that there several representations do exist. The reference you provided also does not address the issue of gimbal lock. As anyone who works in the field of aviation, aerospace, or robotics can attest, failing to worry about gimbal lock opens a door so wide as to let Murphy (as in Murphy's law) and all his evil henchmen pass through in unison.
Dec8-10, 08:33 PM   #6
Craig's book on robotics (the title is either "Introduction to..." or "Fundamentals of...") has a nice treatment of moving back and forth between transformation matrices and poses (x, y, z, rx, ry, rz), as well as a detailed explanation of the 12 sequences. It was a good starting point for me, but unfortunately I don't own the book.
New Reply
Thread Tools
Similar Threads for: Extracting yaw, pitch, roll from transformation matrix
Thread Forum Replies
Calculation of vehicle pitch rate and roll rate from acceleration Classical Physics 12
accelerometer to roll and pitch General Math 2
Robotics Yaw Pitch Roll Euler Angles Calculus 4
how to find roll, pitch yaw.... Mechanical Engineering 1
Plane banking: Pitch and roll axes Engineering, Comp Sci, & Technology Homework 2
