New Reply
Oscillation with Two Springs (SMH)
Share Thread Thread Tools
Dec8-10, 09:43 PM   #1
In the figure below, two springs are attached to a block that can oscillate over a floor. If the left spring is removed, the block oscillates at a frequency of 27 Hz. If, instead, the spring on the right is removed, the block oscillates at a frequency of 43 Hz. At what frequency does the block oscillate with both springs attached?
So I know that f=(1/2pi)*sqrt(k/m)
k=((2*pi*f)^2)
Using these formulas, I solved for each coefficient of friction. Then, I used 1/k= 1/k1 +1/k2 to find the total k value. I plugged that into the frequency equation and got 22.866 Hz. However, webassign tells me that's wrong. Any ideas on where I screwed up? I only have one try left.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Dec8-10, 09:54 PM   #2
Anybody? I'm completely stuck here..
Dec8-10, 10:14 PM   #3
The way you combine the spring constants is not right for this case.
It works if the two springs are connected to each other and then the mass is at the end of one of the springs.
Here is a different situation.
Think about what happens when the object is displaced by [tex]$ \Delta x $[/tex] (either to the left or to the right). What will be the total elastic force on the object? If you answer this question, you will know the "equivalent" elastic constant.
Dec8-10, 10:43 PM   #4
So.. would the force be F= -k1(x)-(-k2)x?
I'm not really sure how to approach the problem this way..
Dec8-10, 11:02 PM   #5
Nevermind, I figured it out! Thanks a lot for the help!
Dec9-10, 08:14 AM   #6
Quote by Dante Tufano View Post
The elastic forces are in the same direction. The force is (k1+k2)x (or minus this if you consider the sign.
New Reply
Tags
harmonic, motion, oscillation, simple, springs
Thread Tools
Similar Threads for: Oscillation with Two Springs (SMH)
Thread Forum Replies
oscillation Introductory Physics Homework 4
Simple Harmonic Motion - oscillation b/w 2 stretched springs Introductory Physics Homework 1
Oscillation: Please Help Advanced Physics Homework 6
Self oscillation Beyond the Standard Model 8
Is damped oscillation a kind of forced oscillation? General Physics 5
