Solve the Problem of Rotating a Strangely-Shaped Slab
  • Thread starter Thread starter mopar969
    Rotating
The problem involves calculating the angle of rotation of a thin slab with a mass of 3.0 kg, shaped by the curves y=4-x^2 and x=0, when subjected to a constant force of 8.0 Newtons applied perpendicularly at the outer bottom corner. The correct approach to solve this problem requires using the area of the object rather than the r^2 dm method initially suggested. After 20 seconds of applying the force, the angle of rotation can be determined using principles of rotational dynamics and the moment of inertia of the slab.
  • Understanding of rotational dynamics
  • Familiarity with moment of inertia calculations
  • Knowledge of the area of irregular shapes
  • Basic principles of force and torque
  • Study the calculation of moment of inertia for irregular shapes
  • Learn about torque and its relationship with angular acceleration
  • Explore the principles of rotational motion in physics
  • Review examples of applying forces to rigid bodies in rotational dynamics
This discussion is beneficial for physics students, educators, and anyone interested in solving problems related to rotational motion and dynamics of irregularly shaped objects.
mopar969
The problem is:
A thin slab of material of uniform density with a total mass 3.0 kg is cut in a strange shape: It is bounded by the curves y=4-x^2 and x=0. Initially it is lying in the xy plane. It is free to rotate about the y axi. A force of 8.0 Newtons is constantly applied perpendicular to the slab at the outer bottom corner. What angle (In radians) has it rotated through after 20 seconds?
A helper on this forum told me to do r^2 dm. However my professor say that this is incorrect and that I need to use the are of the object to answer the problem.
If anybody can help me solve this problem it would be very much appreciated!
  • · Replies 19 ·
  • · Replies 25 ·
9K
23K
