Find Acceleration of 11.5N Bucket Pulled by 9.7N and T Forces
  • Thread starter Thread starter buffgilville
    Acceleration
The problem involves determining the acceleration of a bucket weighing 11.5 Newtons that is being pulled vertically by two forces, one of 9.7 Newtons at an angle of 53 degrees from the vertical and another at 20 degrees from the vertical. The original poster expresses confusion over their calculations and seeks assistance in understanding the net forces acting on the bucket.
  • Participants discuss the calculation of force components and question the method of summing forces in the x and y directions. There is uncertainty about the magnitude of the second force and its role in the calculations. Some participants suggest setting the horizontal force to zero due to the vertical nature of the problem.
The discussion is ongoing, with various participants exploring different interpretations of the problem. Some guidance has been offered regarding the treatment of forces and the need to clarify the unknown magnitude of the second force. There is no explicit consensus on the correct approach yet.
Participants note the absence of the magnitude for the second force and the implications this has on solving the problem. The angles provided are with respect to the vertical axis, which has led to some confusion in the calculations.
buffgilville
A bucket of water which weighs 11.5 Newtons is pulled vertically using two forces. The first of magnitude 9.7 Newtons acts at an angle 53 degrees from the vertical. The second acts at an angle 20 degrees from the vertical. Find the acceleration of the bucket in m/s2. (g = 9.81 m/s^2)
I keep getting 14.03m/s^2 but it's wrong can someone please help.
First I found the sum of Fx = (9.7sin53 + -Tsin20) = 22.65
Then, sum of Fy = (9.7cos53 + Tcos20) = -6.212
Fx + Fy = 16.438
F=ma so, 16.438 divided by (11.5/9.81) = 14.02
What am I doing wrong? ALSO, how do I find the net force acting on the bucket (due to the forces and the weight) in Newtons?
Why did you take the linear sum of Fx and Fy? The magnitude is sqrt(Fx^2 + Fy^2)
Not only that, but your computations of Fx and Fy don't make sense to me. You are never given the magnitude of the second force, yet somehow your unknown (T) just disappears! Am I missing something?
I found T according to the steps in my textbook.
Since the magnitude for the second force is not given, how do I find that?
But that's precisely what I'm saying...I'm not sure how to solve the problem without the magnitude of the second force, and "T" IS the magnitude of the second force! So it totally baffles me how you could have solved for it. :confused:
cepheid, that's what I was having trouble with too because the second magnitude wasn't given.
Since the bucket is pulled vertically, no accelerations are present in the horizontal, hence the sum of "horizontal force" is zero, find the missing tension from there.
arildno is correct. Ax = O, so Fx becomes zero as well (fx = mAx).
but we can still use that information to solve the problem.
i'm going to assume F1 and f2 are along the -x and +x axis.
so sum Fx = 0 = -9.7N(cos53) + F2cos20
9.7Ncos53 = F2cos20
F2 = 9.7Ncos53 / F2cos20 = 6.21N
okay, cool, now we can work with Y components.
sum Fy = 9.7N(sin53) + 6.21N(sin20) Here both are positive b/c they're both pointing up
sum Fy= 9.87N
F = ma
a = F/m = 9.87N/1.17kg = 8.43m/s2 Is that the answer you have?
The x and y components are CORRECT. Yet the Fx must be set equal to 0 because there is no force in the horizontal direction. So set the first equation equal to zero and solve for T. Then use this T for the y component and your problem is solved...
marlon
Hey, this is incorrect. Recall that are angles are given with respect to the vertical axis, not the horizontal axis...
marlon
Thanks Marlon, I get it now :smile:
my pleasure...
marlon
13K
  • · Replies 35 ·
15K
