Calculate what number x needs to be, to make y 0 ?
  • Context: High School
  • Thread starter Thread starter DrWarezz
The discussion revolves around determining the value of x that results in y equaling 0, based on a set of experimental data points. The context includes exploratory reasoning regarding the relationship between x and y, as well as considerations of mathematical modeling and fitting functions to the data.
  • Some participants question the meaning of the equality presented in the data, suggesting that it does not represent true equality.
  • There is a proposal to interpret the data as pairs of (x, y) values to find a function f(x) that describes y.
  • One participant mentions that multiple functions could fit the data, indicating uncertainty about the relationship between x and y.
  • Another participant suggests that the data might fit an exponential decay function or a polynomial of second or higher degree.
  • A specific second-order polynomial is proposed as a fit for the data, with a participant sharing the derived equation.
  • There is a discussion about the appropriateness of fitting a polynomial to three data points, with some acknowledging that it is possible but may not be the best approach for extrapolation.
  • A participant expresses confusion about the technical jargon used in the discussion and requests a simpler explanation.
  • One participant clarifies that the experiment relates to the concentration of potato chips and osmosis.
  • There is a mention of different methods for fitting data, including least squares regression and polynomial fitting, with an emphasis on the importance of understanding the underlying relationship between x and y.
Participants do not reach a consensus on the best approach to determine the value of x for y to equal 0. There are multiple competing views regarding the nature of the relationship between x and y, and the appropriateness of different mathematical models.
The discussion highlights limitations in understanding the relationship between x and y due to a lack of information about the experiment and the definitions of the variables involved. The appropriateness of different fitting methods is also noted as a point of contention.
DrWarezz
#m = 0g
Hi all,
Is it possible to calculate what number x needs to be, to make y 0 ?
An experiment shows that:
x = y
0 = +0.16
1 = -0.38
2 = -0.43
Can I work out from that what x needs to be (it can be as many decimals as you want :-p) for y to equal 0?
Thanks a lot,
[r.D]
Mathematics news on Phys.org
What do you mean by "="??
It most certainly is not "equality" since 1 is NOT equal to -0.38
DrWarezz said:
Hi all,
x = y
0 = +0.16
1 = -0.38
2 = -0.43
Thanks a lot,
[r.D]
:rolleyes:
I think he means:
(x, y)
(0, .16)
(1, -.38)
(2, -.43)
find f() where f(x) = y then find the x that makes y = 0
Alkatran said:
:rolleyes:
I think he means:
(x, y)
(0, .16)
(1, -.38)
(2, -.43)
DrWarezz:
Note that there's a lot of f()'s which satisfy your demand.
Yeah, sorry. I mean:
When x = 0, y = +0.16
When x = 1, y = -0.38
When x = 2, y = -0.43
And the question is, what must x be, so that y = 0?
Sorry for not being to specific at the start..
Can this be worked out?
Sorry, when you say:
What do you mean, by the f() function? :o\
Thanks a lot, and sorry for the delay :)
[r.D]
It can be worked out only if the relationship between x and y is understood.
What experiment is this, and what do x and y refer to in the experiment ?
Without this information, it is impossible to determine what you want.
So happens that this little data set is a prefect fit to some function. It is so perfect, that I cannot believe that it is truly data.
What have you done? Have you plotted the numbers? Remember that a picture is worth a 1000 words.
What did you fit it to integral ?
Looking at the numbers, I'd guess an exponential decay with a negative floor.
Of course, you can always fit it to a polynomial of second or higher degree...but I guess that's not what you mean.
I tried a 2nd order poly. , got R=1. It is a perfect fit,
I did this at home, I am now at work I think the equation was
[tex].245 x^2 -.785x + .16[/tex]
Here is an interesting way of finding the root in this data set is to iteratively evaluate the expression
[tex]x_{n+1} = \frac {.245 x^2 + .16} {.785 x_n}[/tex]
edit:
Let x0 = .1
Shouldn't you always be able to exactly fit a second order polynomial to a set of three points ?
Of Course, you are correct. With the amount of information given that is as good a solution as any.
:o\ Thanks everyone! lol
I'm kind of confused. I'm just a young student, and I got those numbers from a preliminary experiment.
I figured that by using those numbers, could give a pretty accurate result, without even doing the final.
It appears that you lot have figured it out? Could you simplify it a bit, I don't understand half of the jargon you used :o\ lol.
Thanks a lot for the help :)
[r.D]
btw; this is an experiment of the concentration of potato chips.. based around osmosis (how boring eh :P).
So, you've got some data points, 3 in fact. You could try and plot these three points on a graph. The next thing is then to 'guess' the graph of the curve that describes the relationship. You can do this in many ways, and the exact method you choose depends on the situation you're in.
The most common is called 'least squares regression' and this is where you try and draw a straight line that fits 'best' where best is something you can make precise.
There is another method though. Given n points there is a polynomial relation, that is one that looks like:
[tex]y=a_0 + a_1 x +a_2x^2 + \ldots a_{n-1}x^{n-1}[/tex]
that fits exactly through those points.
There are merits for each obviously. Suppose you'd got the data
(-1,1) (0,0.99) (1,1)
then least squares is going to give you something very close to the horizontal straight line y=1 the polynomial will give a parabola that goes off to infinity.
Of course this is an extreme example: in the interval -1 <=x<=1 they're very similar. No one would be silly enough to use such data to predict what the behaviour is like at x = 1000.
Well, I say that but people are that silly.
Just recently someone at Oxford did some studies of data collected over the last 40 years or so about sprinters and extrapolates to predict the woman will win the 100m in less time than the man at the olympics in 150 years time. Very dody science.
More seriously of course was the challenger shuttle disaster when scientists looked at the behaviour of a plastic ring at relatively warm (20deg C) when it behaved perfectly and ignored the fact that at temperatures on the launch pad, near to zero, it became brittle. Feynman I think demonstrated this with a simple experiment on the investigating committee when no one could believe this would be allowed to happen.
I think the o-rings were made of rubber, which has very poor resilience at freezing temperatures.
Anyways, DrWarezz, the important thing to take away from matt's post is that you can only guess what the number would be at y=0, if you know what the relationship between x and y is expected to be.
If you thing y should decrease linearly with increasing x, you can fit a straight line to the data (as matt suggested - using a least squares fit). On the other hand, you might think that it would make more sense for y to decay exponentially, in which case, you would draw a different curve.
And we can't make a guess for what behavior to expect, because we don't know what x and y are.
Okay, thanks a lot everyone.
  • · Replies 48 ·
  • · Replies 24 ·
  • · Replies 22 ·
