Which Has Higher Entropy: HF(g) or Ne(g)?
  • Thread starter Thread starter omni
    Entropy
The discussion centers on the comparison of entropy between two gaseous substances, hydrogen fluoride (HF) and neon (Ne). Participants explore the factors influencing entropy, particularly focusing on molecular complexity and composition.
  • Exploratory, Conceptual clarification
  • One participant questions which of HF(g) or Ne(g) has higher entropy, noting that both are gases and suggesting van der Waals forces do not play a role.
  • Another participant proposes that HF(g) likely has higher entropy due to its greater molecular complexity, which may allow for more randomness.
  • A subsequent reply seeks clarification on why HF is considered a more complex molecule compared to Ne.
  • It is noted that HF is a compound consisting of hydrogen and fluorine, while neon is a monatomic element, which may contribute to the complexity argument.
  • Participants mention that molecular mass is typically a factor in entropy comparisons, but indicate that both substances have similar molecular masses (around 20 g/mol).
Participants express differing views on the relationship between molecular complexity and entropy, with some supporting the idea that HF has higher entropy while others seek further clarification on the complexity aspect. No consensus is reached on which substance definitively has higher entropy.
Participants do not fully resolve the implications of molecular mass on entropy or the specific definitions of complexity being used in the discussion.
omni
Which of the materials have a higher entropy:
HF(g) - Ne(g) ?
Because both of the materials are in State of matter (g) so the van der Waals force are not Affects here.
so how i can know who have higher entropy ?
thanks.
The more complex the molecule, the greater its entropy. My guess would be the HF (g) because it is more complex, and hence has a greater ability to "be random," which is ideally what entropy measures.
OK thank you, but can you Please tell me why HF is more complex molecule ?thanks.
HF is a compound; there is a hydrogen bonded to a fluorine. As for neon, it is just an element by itself.
Usually, the molecular mass comes into play, but they both are about the same. (Around 20 g/mol)
ok thank you.
