Help with integrating arctan function
The discussion revolves around the integration of the function dx / (2 * root(x)) * (1 + x), which is encountered in a Calculus II context. Participants explore the potential connection to arctan integrals and substitution methods.
  • Participants discuss using the substitution u = root(x) and the implications for the differential du/dx. There is uncertainty about how to express the integral correctly in terms of u without retaining x in the expression.
Some participants have offered guidance on the substitution process and the need to express the integral solely in terms of u. There is recognition of the challenges involved in choosing the appropriate substitution and the potential for oversight in the integration process.
Participants reflect on the difficulty of identifying the correct substitution and the nuances of integration techniques, indicating that the problem may involve multiple interpretations of the approach to take.
ssmith147
INTEGRATE dx / (2 * root(x)) * (1 + x)
That's pretty much it!
I received this question on a Calc II exam, so I'm only looking for the solution for my own understanding (I'm sure I already got it wrong). My instinct is that this is an arctan integral in the form of 1 / 1 + u^2. Unfortunately, after playing around with it for about 30 minutes I was unable to find a way to get the denominator into the form 1 + u^2.
Am I missing something or did I misjudge the solution?
Anyw help would be greatly appreciated!
What if you use [tex]\sqrt{x}[/tex] as u?
What does du/dx become, and then the rest of the equation?
u = root(x) so du = 1/(2*root(x)).
INT [1 / ( 2 * root(x))] * [1 / (1 + x)] dx
= INT [1 / (1 + x)] du = ln|1 + x|
That doesn't seem to work, though. If I differentiate this function I only get the original function with respect to u, not with respect to x since the value of u is eliminated by the value of du during the substitution. I've tried playing with this but I'm not seeing a way to successfully balance the value of du and retain u in the function.
Am I missing the obvious here?
You need to express ∫[1 / (1 + x)] du in terms of u with no x at all since you have to integrate with respect to u. So using the substitution u = √x → x = u2, then that gives you ∫du/(1 + u2) which you can now integrate correctly. :smile:
Wow, I can't believe I didn't see that. During the exam I tried using root(x) for u but I never thought about root(x)^2 = x. Tunnel vision must have set in- I should have seen that!
So the answer would be arctan(root(x))- I suppose I can console myself knowing I saw arctan(x) correctly. Devil's in the details, unfortunately.
I really appreciate the feedback on this. At least I know what I did wrong now!
That's it. Knowing (or figuring out) what to make u in these cases can be a real pain in the neck. And in some cases - such as this - it may not be particularly obvious whether simple substitution or integration by parts is necessary.
I was out last night, so thanks to Bohrok for explaining it more thoroughly.
  • · Replies 105 ·
13K
  • · Replies 19 ·
