Energy required to thaw one gallon of ice
  • Context: Undergrad
  • Thread starter Thread starter eniwetok
    Energy Ice
The discussion centers on the energy required to thaw a gallon of ice in a refrigerator, specifically exploring the potential energy savings in refrigerator operation when using ice that has been frozen outside. Participants examine the calculations involved in heating and melting ice, as well as the efficiency of refrigerators.
  • Experimental/applied
  • One participant questions the energy savings from using a gallon of ice in a refrigerator, seeking to quantify it in KWHs.
  • Another participant provides a formula for calculating the energy needed to heat and melt ice, including specific heat capacities and latent heat of fusion.
  • Calculations presented indicate that heating 1 kg of ice from -18C to 0C, melting it, and then heating the resulting water to 2C totals approximately 0.1 KWh.
  • Some participants express surprise at the low energy savings, comparing it to the energy consumption of a 100-watt bulb for an hour.
  • Concerns are raised about the efficiency of refrigerators, noting that the energy consumed from the wall may be higher than the calculated 0.1 KWh due to the refrigerator's efficiency not being 100%.
  • One participant mentions the coefficient of performance (COP) of refrigerators, suggesting that they typically operate at a COP of 2.5:1, implying that the actual energy used may be less than the calculated amount.
  • A suggestion is made to conduct an experiment to measure the refrigerator's energy consumption with and without the addition of ice to gather empirical data.
Participants express varying views on the efficiency of refrigerators and the implications for energy savings. While some calculations are agreed upon, there is no consensus on the actual energy consumption from the wall or the overall effectiveness of using ice in this manner.
Participants note limitations in their understanding of refrigerator efficiency metrics and the lack of specific data on energy consumption, which may affect the conclusions drawn from the calculations.
eniwetok
Not sure if the title does this question justice. My question how much energy in KWHs or a fraction thereof, could be saved in refrigerator operation if someone took a gallon of water, let it freeze solid outside during a 0F degree night, then placed it in their refrigerator until it thawed to around 35F… roughly the ambient temperature in the fridge.
Thanks!
Science news on Phys.org
The energy needed to heat a material is Q = mcT
m is the mass, T is the temperature change and c is the specific heat capacity (in metric units water=4.2KJ/kg/deg C ice=2KJ/kg/deg C)
Then the energy needed to melt the ice (and so the energy given out when ice melts) is called the latent heat of fusion ( 334 kJ/kg for ice->water)
Thanks for responding NS, but you're talking to someone who managed to get through college but hadn't passed a math class since junior HS algebra. LOL
Ok working in metric - cos I don't know the numbers for lbs/fahenheit etc
To heat 1 kg of ice from -18C (approx 0f) to 0C gives Q = 1Kg * 2KJ/kg/degC * 18degC = 36KJ
To melt 1 kg of ice gives Q = 1Kg * 334 KJ/kg = 334KJ
Then heating the water form 0C to 2C (ie 35F) gives Q = 1Kg * 4.2KJ/kg/degC * 2C = 8.4KJ
So overall you get 36KJ + 334KJ + 8.4KJ = 378KJ
378/3600 = 0.1 KWh
378/3600 = 0.1 KWh
Thanks NS... now that makes sense. So it's the same amount of electricity as running a 100 watt bulb for an hour. And at a 10 cents a KWH Guess I was hoping for more savings than a penny. Oh well. Thanks again!
While it is true that it will take 0.1 kWh to warm the ice, that does not mean that it will only consume 0.1 kWh from the wall. That would be the case only if the refrigerator was 100%, which it is not. Unfortunately, I don't have even a ballpark figure for how efficient refrigerators are. While a google search brings up lots of hits, they are mainly concerned with more practical measures of efficiency, and I'm unsure how to convert it.
Anecdotally, my experience with coolers is that if you were to replace a gallon's worth of ice on a daily basis they should be able to keep cool indefinitely. While refrigerators are larger, it suggests to me that it could, at least, help.
It would be rather easy to test with an experiment. Measure the refrigerator's energy consumption for a week, then add a gallon of ice every day for a week and measure it again.
Actually, since refrigerators are moving energy around, not creating useful work, they are not rated in terms of efficiency, but rather COP and they typically have a COP of 2.5:1. So the reality is the refrigerator will use a lot less than .1 kWh to make that ice.
  • · Replies 30 ·
  • · Replies 152 ·
12K
9K
