Determine the deflection angle of a pellet
  • Thread starter Thread starter jpnnngtn
    Angle Deflection
The deflection angle of a plastic pellet with a mass of 7.5 x 10^-10 kg and a charge of 2.00 x 10^-9 C, fired horizontally through an electric field of 9.20 x 10^4 N/C, can be determined using kinematic equations and trigonometric functions. The pellet travels 2 cm horizontally at an initial speed of 150 m/s, allowing the calculation of the time spent in the electric field as 0.0133 seconds. The force acting on the pellet is derived from the electric field using the formula F = E * q, leading to the calculation of vertical displacement and ultimately the deflection angle using arctan of the vertical displacement over the horizontal distance.
  • Understanding of electric fields and forces (E = F/q)
  • Basic kinematics (distance = velocity x time)
  • Trigonometry (arctan function)
  • Newton's second law of motion (F = ma)
  • Calculate the force on charged particles in electric fields using F = E * q.
  • Learn to apply kinematic equations to projectile motion in electric fields.
  • Explore the relationship between acceleration, time, and displacement in physics.
  • Study the principles of parabolic motion and its applications in charged particle dynamics.
Physics students, electrical engineers, and anyone interested in the dynamics of charged particles in electric fields will benefit from this discussion.
jpnnngtn
A plastic pellet has a mass of 7.5 X 10^-10 kg and carries a charge of 2.00 X 10^-9 C. The pellet is fired horizontally betweenm a pair of oppositely charged parallel plates. If the electric field strength between the plates is 9.20 X 10^4 N/C and the pellet enters with an initial speed of 150 m/s, determine the deflection angle.
This is the diagram
Q+ -------------------------------
\deflection angle(not sccurate drawing)
| <-- 2.0cm ----------------->|
*I am almost positive that this problem can be solved by taking the arctan of the change in X over the change in y but i am not sure how to get there. Not in this sense anyway. I can solve these sort of problems when they are not part of electricity.
You know that by entering the electric field, the pellet will experience a force. If I understood the problem correctly the force will be perpendicular to the travel direction of the pellet.
The time spent btw the capacitor can be found; distance/velocity = 2 cm/150
The force can be found since E=F/q
Solve for the force.
F=ma
solve for acceleration
you know the amount of time it has accelerated as well as the value of the acceleration, therefore solve for the distance that the pellet has traveled in the vertical direction.
Now make a triangle. vertical value being the value above, horizontal value being 2 cm. Find the angle of this triangle and there you go.
The pellet follows a parabola, not a straight line so you must get the arctan of vy over vx.
