Automated Launcher: Launching 4m & 50g Projectiles
The discussion revolves around designing an automated launcher for a projectile that must travel 4 meters and weigh no more than 50 grams. The launcher is intended to be mounted on a car, which will stop before launching the projectile sideways. Participants explore various mechanisms and methods for achieving this goal, including the use of gravitational and elastic energy, while also considering timing mechanisms.
  • Experimental/applied
  • One participant suggests that the design needs to clarify whether the launch is vertical or horizontal, and whether the car is moving during the launch.
  • Another participant proposes using a stepper motor with a microcontroller if the goal is to move the car precisely 4 meters.
  • A later reply indicates that the launcher must use only gravitational and elastic energy, with a timer to activate it after the car reaches its destination.
  • Participants discuss various triggering mechanisms, including using a stopping mechanism like a wall or arresting cable to activate the launcher.
  • Some participants propose mechanical timing methods such as an hourglass or water timer, as well as using springs or flywheels for energy storage.
  • One participant suggests calculating the stored potential energy of a spring or elastic mechanism to determine the initial speed of the projectile and optimize its trajectory.
Participants express a range of ideas and suggestions, but there is no consensus on a specific mechanism or design approach. Multiple competing views on the best methods and mechanisms remain unresolved.
Participants have not fully defined the parameters of the project, such as the exact nature of the stopping mechanism or the specifications for the timer. There are also unresolved questions about the projectile's trajectory and the energy calculations involved.
Daruki
i'm trying to build a launcher that automatically launches after a period of time. it has to launch 4m and launches a projectile weighing no more than 50g. what kind of mechanisms would i need to use?
thanks!
Welcome to PF.
There are boundless possibilities here. Can you give us more information on your requirements and your ideas?
Basically, it's mounted on a car. The car and the projectile together cannot be bigger than 40 cm by 30 cm by 25 cm approximately.
I don't really have an idea right now, but I've heard electronic fuses work. It has to have a high degree of accuracy.
OK, you need to give us more information:
Are you launching vertically or horizontally?
Are you launching a projectile from your car?
Is the car moving during the launch?
Do you have a "target"?
Can the project include IC engines, batteries, springs, compressed gasses, etc, etc?
You have utterly failed to define the problem in such a way that anyone can help you. If the object is simply to move a car 4M as precisely as possible, I would use a stepper motor with a uController. Similar "Science Competition Projects" define similar project goals, but with very narrow parameters for power source and control mechanisms.
Fish
Okay, here are more details.
I'm planning to design a car that travels to a destination, stops, and then launches the projectile sideways to the left relative to the car itself. The projectile launcher must use only gravitational and elastic energy, must activate after the car reaches its destination(give or take 10s) and must shoot straight, sideways to the left 4m.
No electronically designed mechanisms, except for the timer, but as of yet, I have no clue as to how to set one up.
There is a target, which is basically a target similar to the game "Darts", where the middle circle is the most accurate which also endows the highest mark.
If the car has some kind of stopping mechanism such as a wall or an arresting cable, as opposed to just coasting to the proper area, I would use that mechanism as the trigger for the launcher.
How about an hourglass? Or a water timer? Spring and flywheel? There are a lot of mechanical ways to do it, and many electrical ways to do it as well.
Hey I'm new to PF, so be gentle if my first few posts aren't gold.
Assuming the car stops on impact...
Have a spring or elastic that releases its stored energy upon impact of the car via quick-release mechanism. From this, you could calculate the stored potential energy and use that to determine the initial speed of your projectile. By altering angle of elevation and height you determine the optimal trajectory to launch the projectile 4m. Hopefully this is on the right track to a solution
  • · Replies 16 ·
  • · Replies 21 ·
39K
