Solve RC Circuit: Find Capacitor Value
The discussion focuses on calculating the value of a capacitor connected to a 2Kohm resistor across a 100Hz power line. The impedance of the capacitor is defined as 1/(jωC), where ω is the angular frequency. Using Ohm's law, the capacitive reactance (Xc) is substituted for resistance, leading to the formula Xc = 1/(2πfC). Given that Xc equals 2000 ohms and the frequency is 100Hz, the capacitance can be determined through rearranging the formula to solve for C.
  • Understanding of Ohm's Law
  • Familiarity with capacitive reactance (Xc)
  • Basic knowledge of AC circuit analysis
  • Proficiency in algebraic manipulation of formulas
  • Calculate the capacitance using the formula C = 1/(2πfXc)
  • Explore the concept of impedance in AC circuits
  • Study the effects of frequency on capacitive reactance
  • Learn about the applications of capacitors in filtering and timing circuits
Electrical engineering students, hobbyists working with AC circuits, and professionals involved in circuit design and analysis will benefit from this discussion.
gregbellows
Hi,
I am stuck on a question to work out the value of a capacitor,
The Question is:
A capacitor and a 2Kohm resistor pass the same current when each is separately connected across a 100Hz power line.
What is the value of the capacitor?
The impedance of a capacitor is
[tex]\frac{1}{j \omega C}[/tex].
The resistance of the capacitor at 100 Hz is just the real part of that impedance (this is the hard part). Use Ohm's law (V = ZI) to solve for the capacitance.
- Warren
- Warren
ohms law shows us that e = i times r, when considering capacitance and frequencies, we substitute r with Xc (capacitive reactance). when a frequency is applied to a capacitor it allows current flow at a rate of ;
Xc=1/[2 * pie(3.14) * f (freq.) *c(farrads)]
***this is the formula for the impedence of a capacitor.
Xc= 2000, f= 100:
therfore C= ? you do the math
  • · Replies 32 ·
  • · Replies 27 ·
9K
  • · Replies 41 ·
