Rotional Motion Time Traveling
The discussion revolves around the concepts of rotational motion, time dilation, and reference frames in the context of special relativity (SR). Participants explore the implications of swinging two clocks, one moving at relativistic speeds, and the effects on time and energy transfer between them.
  • One participant proposes a scenario involving two clocks, one stationary and one spinning at near light speed, questioning the implications for energy density and time differences between them.
  • Another participant seeks clarification on the configuration of the clocks during their rotation, suggesting a model similar to the moon's orbit.
  • A participant emphasizes that time dilation in SR primarily concerns frames of reference, independent of energy transfer or forces, and questions how the second clock would decelerate.
  • There is a request for definitions of time dilation and frame of reference, indicating a need for foundational understanding before proceeding.
  • One participant explains reference frames using a room and a moving wagon, introducing the concept of inertial frames and their relevance to time dilation.
  • Another participant connects the concept of inertia to the discussion, questioning the isolation of the room and wagon and the applicability of instantaneous frames in this context.
  • Clarifications are made regarding the use of inertial frames and the necessity of multiple frames to measure velocity, with a focus on maintaining clarity in the discussion.
Participants express varying degrees of understanding regarding the concepts of time dilation and reference frames. There is no consensus on the implications of energy transfer between the clocks or the necessity of instantaneous frames, indicating ongoing debate and exploration of these ideas.
Participants have not fully resolved the implications of energy density changes during acceleration or the specific mechanics of deceleration for the second clock. The discussion remains open to further exploration of these concepts.
omin
I have a first clock tied to a string. At the other end of the string is the second clock. I swing the second clock around the first clock. I bring the second clock near the speed of light, while the first clock is at near rest compared to me.
A constant force must be applied to the first clock to keep the second clock spinning around it. Does this constant force that produces a near light speed for the second clock mean that the static energy is the same for both clocks?
If not, then does energy become denser in one of the clocks?
If the energy becomes denser in one clock, it must be transferred to this denser area during acceleration. Since both clocks have the same quantity of mass, the internal motion of one clock's mass must then be greater for energy to be denser. Where is this energy transferred from but the other clock? It is transwered during acceleration. During constant rotational motion, the energy gradiant from the first clock to the second clock stays constant. During deceleration, the energy transferred to the clock with greater energy is transferred back to the clock from which the energy came. Therefore, no time change can occur, because energy transfer was equal and opposite in direction during the periods of speed up and slow down.
If the energy doesn't become denser, then there just isn't a density effect and again time couldn't be different in each clock, even during acceleration.
If things at high speeds do appear to have time traveled, then some other force must interact according to the previous logic.
Or what am I missing or mixing up here?
Is the first clock spinning such that if they were cubes, the clocks would constantly be face to face during rotation?
The second clock would behave much like the moon does, only showing the other clock one face while it rotates around the other clock, because the string extend perpendicular from it's center of mass. The string extends tangent from the top of the second clock.
If you want to isolate how these clocks are attached to make the discussion simpler, please do.
Well ok, before this goes too far, I'll first reinstate that within SR, time dilatation deals primarily with frames of reference irrespective of energy transfer, forces, or directions. Two statements from observationnal facts, and an thought experiment involving two mirrors, a flashlight and a traveling wagon are sufficient to demonstrate it quite irrefutably.
Now I must ask, how would you intend to decelerate the second clock? There are many ways, and energy transfer (kinetic energy of the 2nd to whatever form afterwards) will happen differently depending on how you choose to do so.
What do you mean by time dilation?
Please define, frame of reference too. I don't know what you mean.
I'll start with reference frames and we'll work our way to time dilatation.
If I stand in a room, I can view the room as my reference frame. I am at position (x', y') within it. (0,0) being the corner of a room, (x',y') = (2ft, 5ft) my position. Mathematically, it is simply an xy position graph (in 2 dimensions, it could be 1D or 3D).
The room itself however is at position (x,y) relative to another reference frame, that might be the city. The room is at position (x, y) = (1 mile, 3 miles) from city hall. Just about anything that is rigid (room, city, ruler, automobile ...) can be a reference frame.
In the case of the room and the city, two frames are not needed, one would suffice, because they are fixed to one another. But if the room was in a train wagon and the wagon was moving, it is useful to have both frames, and we note them (x,y) for the city frame and (x',y') for the wagon frame.
Roughly stated, special relativity's 2 postulates are :
1. A complete physical experiment will give the same results in whichever reference frame you do it (in a moving wagon or in city hall).
2. The speed of light c is constant.
1. is common sense, and 2 is based on both experiment (Michelson-Morley) and theory (Maxwell's equations, which are themselves based on experiments, and involve all of classical electric and magnetic phenomena).
I got to go, time dilatation in my next post. Think about 2, it is deeper than it sounds.
I understand up until this part:
I'll make an assuption, so you can see what it seems to imply to me.
When I learned about the concept inertia, I imagined an object in motion that had no forces acting upon it. No touching interaction of objects we see, internal interactions changing its velocity or some kind of force field exerting upon it. This object maintains a constant velocity because it has no force acting upon it. (Although this never occurs, it's a necessary theory to isolate a property that can be discussed in relaiton to the others that have been isolated outside of intertia framework.) When you state a room is inside a wagon moving in relation to the rest of the world, is this intertia concept what you are using in the example? Is the wagon and room isolated?
If so or not, is there such a thing as the concept instantaneous in this explanation, like in classical physics? If there is, it is only usefull to use an instantaneous frame if things are moving in relation to one another. Since the wagon moves, then it would be usefull. And, any value of say three frames alows us to deduce or induce certain things about changes in instantaneous frames. Acceleration.
"When you state a room is inside a wagon moving in relation to the rest of the world, is this intertia concept what you are using in the example? Is the wagon and room isolated?"
Yes, since you seem to understand this pretty well, the 1st postulate would indeed be stated more completely if I had said "inertial frame". The wagon will be moving at constant velocity. Introducting acceleration isn't necessary to show time dilatation, so inertia is implied. We can add acceleration and non-inertial frames later and see what happens.
I'm not sure what you mean by "instantaneous frame". Or which event you would qualify to be "instantanous". We don't have to touch the word, nor the concept.
Instantaneous is principally based upon the concept inertia. A moment, frame, or state, which implies constancy. If you choose to eliminate it, we can just use inertial frames though for clarity.
So, intertial frames. The the city frame and room frame are at intertial rest. The room-wagon frame is in an interial motion frame compared to the city. The reason why the room and the city rest intertial frame are not needed because we are interested in intertial motion frames, which is only the wagon room compared to the city?
I want to make sure we are clear on something else. When things are in inertial motion frames, would you agree it only takes two individual consecutive frames to test the velocity of each frame? (Considering the person measuring is in a third inertial frame.)
I don't see what relation you are seeing between "instantaneous" and "inertia", but we simply don't need either concept, so I wouldn't bother with this.
Why would you introduce a 3rd frame to measure the velocity? Whatever velocity the wagoneer sees the city go by is the same as what the citizen sees the wagon go by, and this number is constant in value and opposite in direction.
I introduce it, because we need a velocity of each from the viewer, or there would only be one velocity for both. Do we only need one velocity for all?
All this special relativity stuff is based on the concept that the speed of light appears to be constant regardless of the observers frame of reference (regardless of the observers speed relative to other observers).
If two observers pass by at high speed, it will appear to each obsever that the other guys clock is running slow. At least in the case that the clock is based on the speed of light. Say the clock shoots out a beam of light against a mirror and uses the time it takes the light to travel between 2 parallel mirrors as it's reference for time. Each observer sees the beam of light from his own clock bouncing back and forth between 2 mirrors that move as the same speed the observer moves at. However when looking at the other guys' clock, the beam moves at an angle while it bounces between the 2 mirrors of the clock moving by at high speed. Since the observed speed of light is constant, it appears that the moving clock is running slower, since the beam of light has to travel farther to bounce between the two mirrors moving by at high speed.
Another similar dilema is distance compression at high speeds. If you observe a long object approaching you at very high speed, the time it takes for light at the back of the object to get to you will be less that the time it took for the front of the object to get to you, because the back of the object will have moved closer to you by the time you see the front of the object, and the object will appear to be shorter. However in special relativiy, it's not just appearance, the object has actually shrunk relative to your frame of reference. At the same time your depth is much shorter relative to the any observer in the approaching object. As the object passes by and is departing it appears to get longer (I think).
Back to the original question. It's the acceleration caused by a force that counts here. If force is used to accelerate a vehicle up to high speed, then then used to slow it back down again to return it to it's original frame of reference (like a quick trip to the moon and back), then the time for the acceleratees will have passed by slower than those that didn't get accelerated. When the vehicle returns, it's clocks will be a bit behind those that weren't accelerated. I'll post a thought experiment for this in a bit.
General relativity also addresses accelerations within gravitiation fields, but I'm not aware of what the effect is supposed to be. The statement is made that from within a closed system, you can't tell the difference between acceleration and gravitation. Again using the beam of light bouncing between two mirrors example, both grativity and acceleration (in the "upwards" direction) should cause the beam to move downwards over time. However this ignores the obvious case of a very tall closed system. If it's acceleration that's bending the beam, the beam acclerates downward at the top of the closed system the same as it does at the bottom of the closed system. If it's gravity, the beams rate of downwards acceleration will increase as it approaches the bottom of the closed system, because the pull of gravity is stronger at the bottom of the closed system than it is at the top.
It's true for ALL clocks.
When something is moving relative to you it IS shorter than it's length in its own frame. Always.
Just go with the twin paradox. Because you accelerated you moved further through time.
... You assume the gravity is as strong at the top as it is at the bottom if you're comparing it to acceleration downwards.
That constant force keeps the 2nd clock from flying off into space, but it does not "produce" the "near light speed" for the second clock. That must come from somewhere else.
The second problem with your thought experiment is that there is another force on the 1st clock that you are not considering - it must be anchored to something otherwise the force between the two clocks will send both flying off in a straight line (while revolving around their common center of mass).
Consider the case of a GPS satellite (its easire to use than the moon). The foce that accelerated the satellite up to orbital velocity was provided by a rocket, not by the earth. But the force that keeps the satellite in orbit is provided by the earth. This force makes no difference for SR time dilation (but it does for GR time dilation). Also, since the Earth is so much larger than the GPS satellite, the force they exchange doesn't move the Earth much at all.
Are you looking for a flaw in SR here?
I think there is a language issue here: the word "frame" is not referring to frames in a film. A "reference frame" is simply a set of coordinates in space. So the phrase "individual consecutive frames" has no meaning.
Until they make extremely large flat planets, I'm going to stick with the idea that gravition fields are not constant in strength.
distances appear shorter
After thinking about it, it doesn't matter if the objects are approaching or departing, both will "see" the other as shorter. So I agree here.
Do you think energy source is absolutely necessary? If so, please explain why we miss something crucial. Otherwise, let's not digress from the main point of high speeds supposedly creating time travel.
That sounds principly to be the same argument, just different perspectives. Expanding force(exerting) on the first clock, and compressing force (anchor). The anchoring force must be strong enough to conduct the exerted force though of course.
This sounds interesting, but how is it relevant to a high speed creating time travel?
I would really like to stick to the example I've stated at the beginning of the thread, which isn't a gravity based example, like the one you have stated.
russwatters said:
Are you looking for a flaw in SR here? I think there is a language issue here: the word "frame" is not referring to frames in a film. A "reference frame" is simply a set of coordinates in space. So the phrase "individual consecutive frames" has no meaning.
If you look at the language in this thread, I'm just being carefull so I understand what people mean. I'm not trying to prove anything wrong. That will reveal itself unless those who do comment decide not to be patient and thorough with the vocabulary and principles of the dicussion.
For example, the badly written argument:
Now, we can be more picyunne about the principles and or we can be more picyunne about vocabulary words used. I'm voting for a principly in-depth discussion vs. superficialalities of chosen words. I agree we need to make sure what words are equivalent. Do not assume different words and phaseologies mean meaninglessness or you'll error on the side of vocabularous dogma.
A reference frame is a set of coordinates. Cartesian and geometry concepts give those coordinates numbers. From this we can see length, width and depth of frames. When we combine this with the simple speed concept, we get frames of reference that express displacement compared to other frames. When a frame is checked for displacement compared to another frame, and it has displacement, the two smallest increments noticeable by a human are instantaneous frames. When one instant passes, you have two consecuative frames. Yes, like a film. This geometry is in many physics books and so is displacement. Speed is usually described with a particle type model. Partical displacement seems to be one dimensional displacement. Add two more dimensions and we have frame of reference displacement.
If frames of reference and velocity are not seen like this, then how are they supposed to be seen? If so, I'm on the right track, but didn't explain it real good, then do better.
It's not the high speeds, it's the acceleration to high speed that causes the change in observed time.
That's new to me. I heard that time travel and special relativity was described only with constant velocity, not acceleration. Would you explain then why I acceleration creates time travel?
It's not time travel, it's just changing the rate of time. As posted in another thread, a spacecraft can accelerate to high speed, take a trip to the moon and back, decelerate and end up back on earth. Although both the spacecraft and the Earth observe each other at high speed, only the spacecraft (and its occupants) are affected by the slowing down of time. The clocks on the spacecraft will be a bit behind the clocks on earth.
Acceleration doesn't change time.
Time never changes. What does change is the speed of entities.
If you say something accelerates at a high rate of speed, it only means it moved faster. We know it moved faster because we used a constant to know the rate of acceleration. We wouldn't know the acceleration if we didn't have a constant to base the acceleration upon.
Quantifiable time is does not exist in human consciousness without a known constant in which to compare it to. A quantified constant is needed to test for quantified acceleration. Without a quantified constant, acceleration cannot be quantified. Therefore time travel could not be detected.
To say, oh this thing traveled this far in time, is a quantified acceleration and cannot known without a constant. Time didn't accelerate, a thing did.
Just do a web search for relativity, time, and acceleration, the answers are there.
Not directly, no. But the faster you are going w.r.t to some frame, the higher your rate of travel through time w.r.t that frame's rate of travel through time is.
That's the whole thing with special relativity, it goes against common sense so it's HARD to teach. People won't accept it. I remember my mother telling me the idea of time travel was stupid, because there was only "now", nothing else.
I did enjoy showing her wrong after all these years (I was 12 at the time).
Alkatran,
I don't know what w.r.t. means. Does it mean with reference to?
So far, no one has explained how time travel occurs. Everyone has just said that time does travel when things occur. I've read the descritions on time travel. They're very similar. The problem is, when something seems to contradict itself, I'm not there to catch the author on it. Everyone has left this thread contradictory without explaining things.
It leaves me to believe they don't know what they are talking about because they can't endure a bit of logic.
I apologize for coming to this thread late, and for jumping all the way back to the beginning, but if you will bear with me, I'll make a couple comments.
First, I think your comment about the force applied to the first clock is not right. You need to apply a force to the second clock to keep the second clock spinning about the first clock.
Second, I think you're talking about time dilation, and it really has nothing to do with energy or energy transfer, it's all about relative velocity. A clock on anything moving faster than you will appear to you to run more slowly.
Ok, it will appear to move slowly.
Two questions:
Does the velocity only make it appear that the clock is moving slowly, rather than after being spun at this high velocity for some time, it spin decelerated and stopped, then reads a physically slower time?
And, why does it appear slower because of the high velocity?
Two questions:
Let me preface this explanation with a caveat; I am not an expert in relativity. This is how I understand the situation. So long as your two frames remain inertial, in other words neither of you is experiencing any acceleration, the clock on the frame moving faster than you will appear to run slower to you, but your clock will also appear to run more slowly to an observer on the object that is moving faster than you. And, it will be impossible for you to tell which clock is actually moving more slowly. If something breaks the symmetry of the situation, such as an acceleration of some kind, then it becomes possible to distinguish which clock is actually moving more slowly. This is the general resolution of what is known as the "Twins Paradox."
The short answer as to why the faster clock appears to move more slowly is that is an effect of the constant, finite speed of light. For a detailed explanation as to why the faster moving clock appears to be moving more slowly, imagine you are looking at two parallel plates, one above the other, separated by some distance. Something on the upper plate emits photons at regular intervals, these photons shoot down to the lower plate, which has a mirror on it, bounce off and return to the upper plate where they are counted. Each one of these intervals we'll call a second. This is the classic light clock.
Now, put this clock in horizontal motion and watch it. First the upper plate emits a photon, but since the clock is in motion, the photon doesn't travel straight down any more; the horizontal motion of the clock has given it a horizontal velocity component. So, it travels an angled path to the bottom plate, where it bounces back up towards the upper plate. But, again, since the photon has a horizontal velocity component, it travels an angled path back up to the upper plate. It's clear that the photon's path when the clock is in motion is longer than when it's sitting still, but, the speed of light is constant, so it must take longer to make the whole trip and therefore the clock runs slower in motion than when at rest.
Now, consider that you are moving with the light clock. It appears to you that those photons are just moving straight up and down and the clock is running at the normal speed.
I hope this helped. Any true relativity experts are welcome to comment and correct.
Does the photon really have a horitozonal component added? Since the mirror is moving, could the photons each photon be staggering each time in the direction opposite to motion of the mirrors making the light ray appear to have a horizonatal component?
If this is true, the light ray would not travel in a colinear direction of the light ray, but the light ray would travel in a direction perpendicular to the mirrors.
If it is not true, then the motion of the mirrors which the photon hits determines the velocity of the light, instead of the structure of the mirror soley.
I'm not quite sure I understand what you're trying to depict here. And yes, the photon would have a horizontal component to its velocity since its emitter has a horizontal component.
This is a highly idealized thought experiment to demonstrate the prinicple of time dilation.
  • · Replies 43 ·
  • · Replies 115 ·
10K
  • · Replies 95 ·
9K
  • · Replies 21 ·
  • · Replies 23 ·
  • · Replies 50 ·
