(n )/(2 ^n ) sequence limit problem
  • Thread starter Thread starter courtrigrad
    Limit Sequence
The discussion revolves around the limit of the sequence (n)/(2^n) as n approaches infinity. Participants explore how to find specific values of n that satisfy inequalities involving this sequence, particularly in relation to epsilon values.
  • Participants discuss various methods to determine values of n that keep the sequence below certain thresholds, with some suggesting trial and error while others express concerns about the efficiency of this approach.
There is an ongoing exploration of different methods to find bounds for n, with some participants questioning the validity of certain approaches and others providing insights into the behavior of the sequence as n increases. No consensus has been reached on a definitive method.
Participants mention the need to find specific bounds (N1, N2, N3) for various epsilon values, indicating a focus on the implications of convergence and the behavior of the sequence under different conditions.
courtrigrad
Hello all
If I have a sequence: (n )/(2 ^n )
and I have already proved the lim (n)/ (2^n) = 0
n->00
then how would I find a number N such that (n)/ (2^n) < 1/ 10 ( or any other epsilon)? In other words how would I solve this equation?
Any help would be greatly appreciated
Thanks
You can't really solve this kind of equation (at least to my knowledge). Looks like you're stuck using trial and error.
But that would take a long time (its in Courants book)
Prove by induction that for n>=4, [tex]2^{\frac{n}{2}}\geq{n}[/tex]
1. n=4:
[tex]2^{\frac{4}{2}}=4\geq4[/tex]
2. Let it be true for n=k>=4.
Then,
[tex]2^{\frac{k+1}{2}}=\sqrt{2}2^{\frac{k}{2}}\geq(1+\frac{1}{4})k\geq(k+1)[/tex]
QED
Yea but I am trying to solve for n not prove that its true
That was not the point!
Were you unable to see the trivial consequence:
[tex]\frac{n}{2^{n}}\leq\frac{2^{\frac{n}{2}}}{2^{n}}=\frac{1}{2^{\frac{n}{2}}}[/tex]
How did you even get that? You suddenly threw a proof of induction. But why did you prove it for n/2? I do not understand how you arrived at the so called "trivial" consequence.
Do you agree that I've proven that for n>=4, we have:
[tex]n<=2^{\frac{n}{2}}[/tex]?
In general, let us say we have ( n )/( a ^ n)
For the above problem wouldn't you take the square root of the sequence as such:
sqrt (n) / sqrt ( 2^n)
sqrt(2) = 1 + h
= sqrt(n) / (1+h) ^n <= sqrt(n) / (1 + nh ) <= sqrt(n) / nh
= 1 / nh^2
Could I solve for n using this method? Thank you for all your help
Sorry I was a bit snappish earlier.
Can we focus on your first problem before generalizing?
Yeah, its ok. It's just that in my textbook I think they want me to use a certain method like the one mentioned above. I can see that your method by proof of induction works. Do you think that method mentioned above could work for solving n? Again thanks for all your input!
Frankly, I can't make head or tails of your approach (might be cause I'm tired)
Now, there wasn't anything crucial about proving it for n/2, if that's something you might believe (you could just as easily make an induction argument on n/3 or 123/758n, for that matter).
The crucial idea is that an "exponential" grows faster than a "polynomial"
That is, an exponential function (as long as the base is greater than one) will always catch up with a polynomial. That's essentially the main idea behind the induction proof.
More Limits
Hello again. Here is the problem. In each one we are defining smaller and smaller epsilons. Can you please help? Also what if you had n^2 / 2^n = 0?
At the very first, trial and error were suggested. Why did you declare "that would take too long"? It takes a heckofalot less time than reading all of these posts!
f(n)= n/2n
n f(n)
1 1/2
2 2/4= 1/2
3 3/8
4 4/16= 1/4
5 5/32= .15625
6 6/64= .09375 and we're done.
n= 6.
HallsofIvy you are correct but here is the problem:
The other problems choose epsilon smaller and smaller such as:
(n/2^n) < 1/100
(n/2^n) < 1/1000
How would I find n now? Guess and check would take a very long time. I know by the definition of convergence:
|(n/ 2^n)| < 1/100 (for example) for ever N(epsilon) > n. So when I choose epsilon smaller and smaller, n will become larger and larger. Can someone please help me?
THanks a lot
(n/2^n) < 1/100
(n/2^n) < 1/1000
If you recognize that:
1. The sequence is monotone decreasing.
and
2. That it shrinks quite rapidly
guess and check is really fast.
For example, I could just try n=1, n=10, then n=100 and so on. Since the sequence is monotone, if the n'th term is inside epsilon, all the following terms are also inside epsilon, and you don't have to find the smallest n, just one that works.
Arnildo already showed that for [tex]n>2[/tex], [tex]\frac{2^{\frac{n}{2}}}{2^n} > \frac{n}{2^n}[/tex]
But [tex]\frac{2^{\frac{2}{n}}}{2^n}=\frac{1}{2^{\frac{n}{2}}}[/tex]
which you can easily use to get a floor for [tex]n_\epsilon[/tex]
yes but i need to find N1, N2, and N3 such that n> N1, n> N2, n > N3. This means that I need to find nuumbers N1, N2, and N3 such that any number greater than these numbers satisfies the inequality. Thus I cannot choose 'any number.' For example with the problem above, the answers are 6, 10, 14 respectively (1/10, 1/100, 1/1000). You notice that for each of these numbers is a lower bound. I would I find this.
Again thanks a lot everyone!
Does this involve finding Bounds?
Would guess and check still be the best way to go. In Courant's book it says to "find" the numbers. Does that mean that you should guess and check?
Thanks
  • · Replies 21 ·
