Calculating pH of a solution with two weak acids and a strong base
  • Thread starter Thread starter sparkle123
    Acids Base Weak
The discussion focuses on calculating the pH of a solution containing 0.5332 M acetic acid (CH3COOH), 0.1219 M sodium acetate (CH3COONa), 0.100 M hydrogen sulfide (H2S), and 0.41452 M sodium hydroxide (NaOH). The key conclusion is that neutralization occurs, but the strong base does not fully neutralize the weak acids. The Henderson-Hasselbalch equation can be applied to determine the pH after accounting for the neutralization of the strongest acid first, which is acetic acid in this case.
  • Understanding of weak acid and strong base neutralization reactions
  • Familiarity with the Henderson-Hasselbalch equation
  • Knowledge of acid dissociation constants (Ka) for CH3COOH and H2S
  • Basic skills in stoichiometry and solution concentration calculations
  • Calculate the pH using the Henderson-Hasselbalch equation for a buffer solution
  • Explore the impact of varying concentrations of weak acids on pH
  • Study the concept of buffer capacity in solutions with multiple weak acids
  • Investigate the stepwise neutralization of polyprotic acids like H2S
Chemistry students, educators, and professionals involved in acid-base chemistry, particularly those dealing with buffer solutions and pH calculations in laboratory settings.
sparkle123
0.5332 M CH3COOH
0.1219 M CH3COONa
0.100 M H2S
0.41452 M NaOH
what is the pH of the resulting solution?
CH3COOH Ka=1.75E-5
H2S Ka1=9.6E-8, Ka2=1.3e-14
I know that neutralisation will occur, but there is not enough strong base to neutralize all of the weak acids. How do you know how much of each acid the base will neutralize? How would you calculate pH then? I know if there was one weak acid you could use the Hendelson-Hasselbach equation but I don't know what do with two weak acids :(
Strongest acids are neutralized first.
Idea of using Henderson-Hasselbalch equation is a right one, just start with the first hint and see what you get after using all base.
yup
borek has provided u with almost all of the reqd. hints!:-p
  • · Replies 20 ·
