Confused by wikipedia on (torque-free) precession
The discussion clarifies the concept of torque-free precession, specifically addressing the relationship between angular momentum (L), moment of inertia tensor (I), and spin angular velocity vector (ωs). It establishes that while L remains constant in the absence of torques, the moment of inertia tensor can vary, necessitating a change in ωs over time. The participants agree that defining angular momentum in the moving frame provides clarity, especially when deriving equations for ω using Euler's equations. This approach contrasts with the stationary frame, which simplifies the understanding of constant angular momentum.
  • Understanding of angular momentum (L) and moment of inertia tensor (I)
  • Familiarity with spin angular velocity vector (ωs) and its significance
  • Knowledge of Euler's equations in rotational dynamics
  • Basic concepts of reference frames in physics
  • Study the derivation of Euler's equations for rotating bodies
  • Explore the implications of changing moment of inertia in dynamic systems
  • Learn about the differences between fixed and moving reference frames in physics
  • Investigate real-world applications of torque-free precession in engineering
Physics students, mechanical engineers, and anyone interested in the dynamics of rotating systems will benefit from this discussion, particularly those studying angular momentum and precession.
nonequilibrium
Hello, I quote http://en.wikipedia.org/wiki/Precession from the first paragraph from the first section ("Torque-free precession"):
For example, when a plate is thrown, the plate may have some rotation around an axis that is not its axis of symmetry. This occurs because the angular momentum (L) is constant in absence of torques. Therefore it will have to be constant in the external reference frame, but the moment of inertia tensor (I) is non-constant in this frame because of the lack of symmetry. Therefore the spin angular velocity vector (ωs) about the spin axis will have to evolve in time so that the matrix product L = Iωs remains constant.
But isn't the matrix product L = Iωs relative to the moving frame (that's how we did it in our course anyway), meaning L and omega are indeed the vectors as defined/seen from the absolute/fixed frame, but the matrix product has the components from the moving/relative frame. In that case, those components of L don't have to be fixed, since a fixed L in the absolute frame will seem to be rotating/changing when seen from the moving frame.
hello mr. vodka! :smile:
the angular momentum (I) is best defined in the moving frame (the frame fixed in the body and rotating with it) because it's fixed in the structure, and in a stationary frame it would be changing
but you can define the angular momentum in the stationary frame, which is what wikipedia is doing to make it clear that a constant Iω and a changing I means a changing ω
we can work in either frame …
if all we want to show is that ω must be changing, then the stationary frame is easiest, but if we want to actually find the equation for ω, it's best to use the moving frame and Euler's equations :wink:
Aha, that makes a lot of sense, thank you! :)
  • · Replies 49 ·
  • · Replies 39 ·
  • · Replies 35 ·
