Group generation and normal subgroups
The discussion centers on proving that the subgroup generated by the conjugacy class of an element x in a group G is normal in G. The user demonstrates that is invariant under conjugation by analyzing elements of in two cases: when k is positive and negative. The argument confirms that any element y in remains in after conjugation, thereby establishing that is indeed a normal subgroup of G. The clarification provided by Tinyboss emphasizes that it suffices to verify invariance under conjugation for a set of generators.
  • Understanding of group theory concepts, particularly conjugacy classes.
  • Familiarity with the definition and properties of normal subgroups.
  • Knowledge of group operations and their properties, including conjugation.
  • Basic proficiency in mathematical induction.
  • Study the properties of normal subgroups in group theory.
  • Learn about conjugacy classes and their significance in group structure.
  • Explore the concept of group generation and how to construct generated subgroups.
  • Investigate examples of normal subgroups in specific groups, such as symmetric and alternating groups.
Mathematicians, students of abstract algebra, and anyone studying group theory, particularly those interested in subgroup properties and normality.
Bleys
There is a step in some book which is vaguely explained, I just want to check whether my working is correct.
Let G be a group, and let x be in G-{1}. Let Y be the set [itex]\left\{g^{-1}xg : g\in G\right\}[/itex].
I want to show <Y> is normal in G. Now it's clear why Y is invariant under conjugation (Y being itself a conjugacy class, namely of x). The book says that from this it follows <Y> is normal, but I didn't really think it that was clear. Why does it follow that also <Y> is invariant under conjugation?
This is what I've done, but I don't know if it's correct (or if it's even the argument the book is implying):
any y in <Y> is of the form [itex]g^{-1}x^{k}g[/itex] where k is a positive integer, or [itex]gx^{k}g^{-1}[/itex] where k is a negative integer. I'll do k=2;the rest follows by induction.
First case: [itex]g^{-1}g^{-1}x^{2}gg = g^{-1}(g^{-1}xg)(g^{-1}xg)g = g^{-1}(g^{-1}xg)gg^{-1}(g^{-1}xg)gg[/itex]Since Y is invariant under conjugation, this is a product of two elements in Y hence in <Y>.
Second case: [itex]g^{-1}gx^{-2}g^{-1}g = x^{-2}[/itex], which is clearly in <Y> since x is in Y.
Then for any y in <Y>, [itex]g^{-1}yg[/itex] is in <Y>.
Is this correct? Is there a simpler way to do it?
EDIT: I don't know why the code is not showing for the First case...
It's because [tex]g^{-1}(ab)g=(g^{-1}ag)(g^{-1}bg)[/tex], i.e. conjugation distributes over products, so you only need to verify invariance under conjugation for a set of generators.
oh ok; thanks Tinyboss!
  • · Replies 26 ·
  • · Replies 18 ·
  • · Replies 41 ·
