Where Does the Missing Factor in the Virial Theorem Derivation Come From?
The discussion revolves around the derivation of the Virial Theorem, specifically relating average internal pressure to gravitational potential energy. Participants are examining the mathematical expressions involved and questioning the presence of a missing factor in the derivation.
  • Participants discuss the integration process and the variables involved, particularly questioning the use of 'dm' in the context of gravitational mass. There is also exploration of the relationship between gravitational energy and the derived expressions, with some participants suggesting alternative interpretations of the variables.
The discussion is active, with participants providing insights and questioning assumptions. Some have offered clarifications regarding the definitions and relationships within the derivation, while others are still seeking to understand the implications of the missing factor.
There is an ongoing debate about the correct interpretation of gravitational potential energy and the integration limits, with references to specific forms of the energy expressions. Participants are also considering the implications of different constants and factors in the equations.
Piano man
Currently working through a derivation of the Virial Theorem relating average internal pressure to gravitational potential energy.
So I've got to
[tex]-3\int^V_0 Pdv=-\int^M_0 \frac{Gm}{r}dm[/tex]
which is meant to give
[tex] 3 \langle P \rangle V=-E_{grav}[/tex]
But if I'm right in saying that [tex]E_{grav}[/tex] is [tex]\frac{GM^2}{r}[/tex] then the above integral on the rhs gives an extra factor of 1/2.
What am I missing?
Are you sure the 'dm' should be referring to the same 'm' as the one in the integrand?
I.e. maybe it should me dm' ("dee-em prime")?
That would give the right answer yes, but I don't see any justification for it.
The 'm' refers to the gravitational mass within radius r, and dm has already been substituted in for [tex]4\pi r^2\rho dr[/tex]
So do you see any reason for using [tex]dm'[/tex] other than the fact that it works?
could you state the problem precisely?. The virial theorem I know relates relates mean values in time of kinetic energy and potencial energy
This is the part of the derivation before you introduce kinetic energy.
Starting with [tex]\frac{dP}{dr}=-\frac{Gm\rho}{r^2}[/tex]
Multiplying both sides by [tex]4\pi r^3[/tex] and integrating over the entire radius of the star:
[tex]\int^R_0 4\pi r^3\frac{dP}{dr}dr=-\int^R_0\frac{Gm}{r}4\pi r^2\rho dr[/tex]
Integrating the left by parts, and subbing [tex]dm=4\pi r^2\rho dr[/tex] on the right:
[tex]\left[4\pi r^3P\right]^R_0-3\int^R_04\pi r^2Pdr=-\int^M_0\frac{Gm}{r}dm[/tex]
The first term on the left is 0 since P(R)=0, ie, pressure at the surface.
Sub in volume of spherical shell [tex]dv=4\pi r^2dr[/tex] and you get the original equation in the first post:
[tex]-3\int^V_0Pdv=-\int^M_0\frac{Gm}{r}dm[/tex]
From that you can relate the average pressure to the gravitational energy, and also to the thermal energy and mash things up a bit to get the familiar Virial theorem.
But for now, I'm still wondering where the factor of 1/2 has gone. Any ideas?
And thanks for your contributions so far! :D
I think that is correct when you assert that
[tex]E_{grav}=-\int^M_0 \frac{Gm}{r}dm[/tex]
but don't thing is correct to say that
[tex]E_{grav}=\frac{GM^2}{r}[/tex]
Thank you - I was beginning to start thinking something similar, because I found somewhere referring to
[tex]E_{grav}=\alpha\frac{GM^2}{R}[/tex]
so I'm guessing the alpha accounts for the 1/2.
It would be interesting to know what other values it could take...
Thank you very much for your help.
The way I understand it is that the integration can not be calculated without knowing m as a funtion of r so the factor 1/2 is not correct. You simply must realize that the integral is the correct expresion for E_grav.
Okay that's logical. Thank you.
