Stability of the equilibrium point (Matlab)
The discussion revolves around the stability analysis of a 3-DOF system characterized by a 6th order characteristic polynomial. Participants explore numerical methods in MATLAB to plot the real parts of the roots as a function of the parameter beta, with a focus on identifying stability ranges and bifurcation points.
  • One participant presents a characteristic polynomial and seeks guidance on plotting the real parts of its roots in MATLAB as a function of beta.
  • Another participant provides a MATLAB code snippet that successfully computes the roots and suggests using symbolic representation for further analysis.
  • A third participant shares their working code and plots the real parts of the roots, indicating a specific stability threshold for beta.
  • One participant questions the effectiveness of the plot, suggesting that visualizing each root's trend with beta may provide more meaningful insights.
  • A later reply discusses the implications of the plot, noting a stability range and expressing interest in determining parameters related to a Hopf bifurcation.
Participants generally agree on the approach to plotting the roots and the significance of the stability threshold identified. However, there is a disagreement regarding the best way to visualize the data, with differing opinions on the utility of the presented plots.
Participants have not fully resolved the implications of the Hopf bifurcation or the specific values of beta_H and frequency Omega_H, indicating ongoing exploration of these concepts.
Researchers and students interested in stability analysis, numerical methods in MATLAB, and bifurcation theory may find this discussion relevant.
PhMichael
After analyzing a 3-DOF system, I've obtained the following 6th order characteristic polynomial:
[tex]P=\lambda^6+(6\beta-.8896)\lambda^5+(8\beta^2-3.5584\beta+6)\lambda^4+(\beta^3-.8896\beta^2+16\beta-3.5584)\lambda^3+(3\beta^2-1.7792\beta+8)\lambda^2+(3\beta-.8896)\lambda+1[/tex]
Stability is determined by the real part of the roots of the this polynomial. Now, I need to vary numerically (matlab) the conditions for [tex]Re(\lambda)[/tex], in other words, I want to plot the real part of the [tex]\lambda[/tex]'s as a function of [tex]\beta[/tex], where [tex]0<\beta<1[/tex] ... How can I do that in matlab? - I tried to use the "solve" command, however, it doesn't even produce an explicit answer.
Thanks!
Ok thought about this and yes, what I posted does give the solution. Good thing [tex]\beta[/tex] is bounded or else things would get complicated
Code:
 n=1000;
beta = linspace(0,1,n);
%coefficients of polynomial
coeff = [1 (6*beta-.8896) (8*beta.^2-3.5584*beta+6) ...
(beta.^3-.9986*beta.^2 +16*beta-3.5584) ...
(3*beta.^2-1.7792*beta+8) (3*beta*.8896) 1];
%solve for roots.
r=cell(n,1);
r_part = cell(n,1)
for i=1:n
r{i} = roots(coeff(i));
r_part{i} = real(r{i});%collect real part of roots
end
Now you have roots as a function of [tex]\beta[/tex]
Also if you have it in symbolic format you do know how to do the same thing as above correct?
Replace the fourth line with:
Code:
coeff = wrev(coeffs(P))
where P is the symbolic equation in post #1, and of course substitute the value of beta for the linspace values.
Thanks a lot, viscousflow! ... After an intense struggle, I've managed to write a working code =) ... It goes like this:
Code:
G=0.8896;
beta=0:0.01:1;
A=zeros(6,size(beta));
a1 = 1 ;
a2 = 6.*beta - G ;
a3 = 8.*beta.^2 - 4.*beta.*G + 6 ;
a4 = beta.^3 - G.*beta.^2 + 16.*beta - 4.*G ;
a5 = 3.*beta.^2 - 2.*beta.*G + 8 ;
a6 = 3.*beta - G ;
a7 = 1 ;
for i=1:length(beta)
    P=[a1 a2(i) a3(i) a4(i) a5(i) a6(i) a7];
    R=roots(P);
    Re=real(R);
    A(:,i)=Re';
end
plot(beta,A,'linewidth',3,'markersize',10)
grid;
ylabel ('Re(\lambda)')
xlabel ('\beta')
Thats good, however, I don't see how you'd get meaningful information from plotting Re(roots) versus Beta like that. You have 6 roots so I thought you'd want to see the trend of each root with beta. That's the advantage of the cell structure I had above, but that's just me.
Have a good day.
http://img831.imageshack.us/img831/1715/plotb.png
Uploaded with ImageShack.us
I need to plot [tex]Re(\lambda)[/tex] as a function of [tex]\beta[/tex] in order to find the stability range. According to the figure, the system is stable for [tex]\beta > 0.4457[/tex], while for [tex]\beta<0.4457[/tex], there exists at least one eigenvalue (root) with a non-negative real part and the system is unstable ... so far so good ...
Now, I want to determine [tex]\beta_H[/tex] and the frequency [tex]\Omega_H[/tex], which correspond to the Hopf bifurcation ... How can I do that?
  • · Replies 69 ·
9K
12K
16K
