New Reply
Time Delay
Share Thread
Jan9-11, 05:44 AM   #1
Time Delay
Consider the spacetime metric
[latex]ds^2=-(1+r)dt^2+\frac{dr^2}{(1+r)} + r^2 ( d \theta^2 + \sin^2{\theta} d \phi^2)[/latex]
where [latex]\theta, \phi[/latex] are polar coordinates on the sphere and [latex]r \geq 0[/latex].
Consider an observer whose worldline is [latex]r=0[/latex]. He has two identical clocks, A and B. He keeps clock A with himself and throws clock B away which returns to him after an interval of 4 minutes according to clock B. What time interval has elapsed on clock A?
So by setting [latex]r=0[/latex] the mteric simplifies to
[latex]ds^2=-dt^2+dr^2[/latex]
Now I said that we can assume that the clock will travel on a timelike geodesic (since it is essentially a massive particle). And so using [latex]g_{ab}u^au^b=-1[/latex] for timelike geodesics we get
[latex]-1= \left( \frac{dt}{d \tau} \right)^2 + \left( \frac{dr}{d \tau} \right)^2[/latex].
Now I'm stuck. We know A is measuring proper time I think and so I imagine we want to solve this equation for [latex]\frac{dt}{d \tau}[/latex] and then use that to get an equation for t in terms of tau and then solve for tau when t is equal to 4. Am I right?
Also, is [latex]g_{ab}u^au^b=-1[/latex] true for any timelike curve or just for timelike geodesics, and if so, why?
Thanks a lot.
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Jan10-11, 08:16 AM   #2
You cannot set r=0 for clock B which is travelling.It will travel on a radial trajectory, so theta and phi are constant.
Jan10-11, 08:35 AM   #3
Quote by betel View Post
Will it be timelike?
So do I get [latex]-1=-(1+r) (\frac{dt}{d \tau})^2 + \frac{1}{1+r} ( \frac{dr}{d \tau} )^2[/latex]?
How do I go about solving this?
Jan10-11, 09:33 AM   #4
Time Delay
Yes it is a normal massive particle, so it has to be timelike.
So far you only have one equation for two unknown functions. You have to use the e.o.m. for a geodesic to eliminate one of them.
Jan10-11, 11:54 AM   #5
Well how is this:
[latex]L=-(1+r) \dot{t}^2 + \frac{1}{1+r} \dot{r}^2 + r^2 \dot{\theta}^2 + r^2 \sin^2{\theta{ \dot{\phi}^2[/latex]
So it seems like this is going to be simplest to use Euler Lagrange on the t coordinate so we get:
[latex]\frac{\partial L}{\partial x^\mu} = \frac{d}{d \tau} \left( \frac{\partial L}{\partial \dot{x}^\mu} \right)[/latex]
[latex]\Rightarrow \frac{d}{d \tau} \left( -2 (1+r) \dot{t} \right)=0[/latex]
Now by cancelling the -2 and then by product rule we get
[latex] \dot{(1+r)} \dot{t} + (1+r) \ddot{t}=0 \Rightarrow \dot{r} \dot{t} + ( 1+r) \ddot{t}=0 \Rightarrow \dot{r} = - \frac{(1+r) \ddot{t}}{\dot{t}}[/latex]
Is this correct? Should I go ahead and substitute this back in?
Thanks!
Jan10-11, 02:40 PM   #6
How did you get the idea to take the norm of the velocity as Lagrange function?
Somewhere in your lecture you should have derived something called geodesic equation or similar. It should be a differential equation defining the motion of a particle on a geodesic. The equation with the -1 in your first post follows from this differential equations.
So you need one of these explicit equations to help you eliminate one function.
Jan10-11, 06:32 PM   #7
Oops. Kind of went of at a tangent there!
So the geodesic equation is
[latex]\frac{d^2 x^\mu}{d \tau^2} + \Gamma^\mu{}_{\nu \rho} x^\nu x^\rho=0[/latex]
So I assume I want to get rid of [latex]\frac{dr}{d \tau}[/latex] since we are interested in how [latex]t[/latex] varies with [latex]\tau[/latex].
So if I pick [latex]x^\mu=r[/latex] then
[latex]\frac{d^2r}{d \tau^2} + \Gamma^r{}_{\nu \rho} x^\nu x^rho=0[/latex]
Now [latex]\Gamma^\mu{}_{\nu \rho} = \frac{1}{2} g^{\mu \sigma} \left( g_{\nu \sigma, \rho} + g_{\sigma \rho, \nu} - g_{\nu \rho, \sigma} \right)[/latex]
Now if we take [latex]\mu=r[/latex] then the only non zero component is
[latex]\Gamma^r{}_{rr} = \frac{1}{2} g^{rr} g_{rr,r} = \frac{1}{2} \left( - \frac{1}{1+r} \right) \left( \frac{1}{(1+r)^2} \right) = - \frac{1}{(1+r)^3}[/latex]
So this would go back into the geodesic equation to give
[latex]\frac{d^2r}{d \tau^2} - \frac{1}{(1+r)^3} \left( \frac{dr}{d \tau} \right)[/latex]
And hence [latex]\left( \frac{dr}{d \tau} \right)^2 = - (1+r)^3 \frac{d^2r}{d \tau^2}[/latex]
So should I substitute this back in? How would I get rid of the [latex]\frac{d^2r}{d \tau^2}[/latex] term?
Also, can you remind me how we derive the equation [latex]g_{ab}u^au^b=-\sigma[/latex] please?
Thanks again!
Jan11-11, 02:24 AM   #8
Up to the definition of the Christoffel symbol you are correct. Then you calculated [tex]\Gamma^r_{rr}[/tex] wrong. The mistake is in [tex]g^{rr}[/tex]. And the 1/2 disappeared. But this is not the only nonzero component.
To dervie that the norm is constant it is convenient to first rewrite the geodsic equation in the following form.
[tex]\frac{d u_\alpha}{d\tau} - \frac{1}{2}\partial_\alpha g_{\mu\nu}u^\mu u^\nu=0[/tex]
Then all you have to do is act with [tex]\frac{d}{d\tau}[/tex] on [tex]g_{\alpha\beta}u^\alpha u^\beta[/tex] and reshuffle the derivatives and use the above geodesic equation.
Jan11-11, 06:06 AM   #9
Ok. So I find that
[latex]\Gamma^r{}_{rr}=-\frac{1}{2(1+r)}[/latex]
However, from the definition
[latex]
[/latex]
We see that having picked [latex]\mu=r[/latex], we must take [latex]\sigma=r[/latex] but we can get a contribution from the third term in the definition of the Christoffel symbols when [latex]\nu=\rho[/latex] also,
So [latex]\Gamma^r{}_{tt}=-\frac{1}{2}(1+r)[/latex]
[latex]\Gamma^r{}_{\theta \theta}=r(1+r)[/latex]
[latex]\Gamma^r{}_\phi \phi} = r(1+r) \sin^2{\theta}[/latex]
So are all these correct now? What's next? Plug them back into
[latex]\left( \frac{dr}{d \tau} \right)^2 + \left( \frac{d t }{d \tau} \right)^2=-1[/latex]?
And secondly, you wrote [tex]
[/tex]
What happened to the 1st and second terms from the Christoffel symbol?
Thanks.
Jan11-11, 07:06 AM   #10
The Christoffel symbols now are correct. You should now write the relevant geodesic equations and try to find out which ones to use to solve for r(tau) and t(tau).
You have to notice that compared to the original geodesic equation this one is now for the kovariant velocity. You should try to derive my expression from the usual one, but it is straight forward.
Jan11-11, 07:47 AM   #11
You have to notice that compared to the original geodesic equation this one is now for the kovariant velocity. You should try to derive my expression from the usual one, but it is straight forward.[/QUOTE]
Surely there is only one geodesic equation, namely:
[latex]\frac{d^2r}{d \tau^2} - \frac{1}{2(1+r)} \left( \frac{dr}{d \tau} \right)^2 - \frac{1}{2} ( 1+r) \left( \frac{dt}{d \tau} \right)^2 + r (1+r) \left( \frac{d \theta}{d \tau} \right)^2 + r(1+r) \sin^2{\theta} \left( \frac{d \phi}{d \tau} \right)^2=0[/latex]
I don't see how I can solve this for r(tau) or t(tau) since I now have one equation and 5 unknowns!!!
Sorry but I don't understand what you mean here.
Jan11-11, 07:58 AM   #12
No. You have for equations. One for each t,r,theta,phi. And two of the functions are known. The observer throws the clock on a radial trajectory, so theta=const and phi=const.
So you have two differential equations for two unknown function which is enough to solve the problem. Or you can use one of the DE and the relation for the norm of the velocity, which will give the same result.
On the expression for the geodesic equation: What I meant is that both expressions are equivalent.
[tex] \frac{d u_\alpha}{d\tau} - \frac{1}{2}\partial_\alpha g_{\mu\nu}u^\mu u^\nu=0\Leftrightarrow \frac{d^2 x^\mu}{d \tau^2} + \Gamma^\mu{}_{\nu \rho} u^\nu u^\rho=0\Leftrightarrow \frac{d^2 x_\mu}{d \tau^2} - \Gamma^\nu{}_{\mu \rho} u_\nu u^\rho=0[/tex] and you can use whichever one is more convenient to you.
The derivation of this relation will be about four lines, so you should try to prove it.
Jan11-11, 07:59 AM   #13
Btw. in your first formula for the geodesic equation you accidentially wrote [tex]x^\nu x^\rho[/tex] instead of [tex]u^\nu u^\rho[/tex] but correctly used the u later on.
Jan11-11, 08:01 AM   #14
Thanks but why is it four seperate equations. Surely in the definition of the Christoffel symbols, we are using Einstein summation convention and so the [latex]\nu,\rho[/latex] indices are summed over, no?
Jan11-11, 08:02 AM   #15
Yes, but you have on free index, alpha.
I just realized, that it is you again latentcorpse :)
Seems I always choose to answer your questions. Where are studying?
Jan11-11, 08:13 AM   #16
I don't get it.
We have
[latex]
[/latex]
So surely the free index is [latex]\mu[/latex]. Now we have picked [latex]\mu=r[/latex] but the [latex]\nu, \rho[/latex] indices are dummy (i.e. summed over) so surely we would have
[latex]\frac{d^2 r}{d \tau^2} + \Gamma^r{}_{tt} u^tu^t +\Gamma^r{}_{rr} u^ru^r + \Gamma^r{}_{\theta \theta} u^\thetau^\theta + \Gamma^r{}_{\phi \phi} u^\phi u^\phi=0[/latex]
No?
And for the derivation of the norm of the velocity equation I multiplied the whole thing through by [latex]g_{\mu \lambda}[/latex] to get:
[latex]\frac{d^2 x_\lambda}{d \tau^2} + \frac{1}{2} g_{\mu \lambda} g^{\mu \sigma} ( g_{\nu \sigma, \rho + g_{\sigma \rho, \nu} - g_{\nu \rho, \sigma}) u^\nu u^\rho=0[/latex]
[latex]\frac{d^2 x_\lambda}{d \tau^2}+\frac{1}{2} ( g_{\nu \lambda, \rho} + g_{\lambda \rho, \nu} - g_{\nu \rho, \lambda})u^\nu u^\rho=0[/latex]
And then if we relabel [latex]\lambda \rightarrow \mu[/latex] and use the symmetry fo the metric and the u terms, we can rewrite it as
[latex]\frac{d^2x_\mu}{d \tau^2} + \frac{1}{2} ( 2g_{\nu \mu,\rho} - g_{\nu \rho,\mu})u^\nu u^\rho=0[/latex]
So it appears I have an extra term that you don't have?
And I'm studying at Cambridge but as you can probably tell Im finding it pretty tough. What about you, where do you study/work?
Jan11-11, 08:22 AM   #17
Quote by latentcorpse View Post
We have
[latex]
[/latex]
Yes. But you could equally pick mu=t. This would be the second equation.
Careful: You cannot pull the metric through [tex]\frac{d}{d \tau}[/tex] This is not a covariant derivative.
I think it is easier if you start with the metric inside and then pull it out step by step.
[tex]\frac{d}{d\tau}(g_{\alpha\beta}u^{\beta}= \ldots[/tex]
Then using writing [tex]\frac{d}{d\tau}=u^\alpha\frac{\partial}{\partial x^\alpha}[/tex] you should be able to make the calculation.
I'm in Munich doing a Ph.D. in Cosmoloy.
New Reply
Similar discussions for: Time Delay
Thread Forum Replies
Time Delay Relay Electrical Engineering 5
C++ Time Delay Programming & Comp Sci 4
Time Delay of Neutrinos Introductory Physics Homework 1
Time delay Electrical Engineering 6
Time Delay in C++. Programming & Comp Sci 18
