First order differential equation
The discussion focuses on solving the first-order differential equation dy(t)/dt + 3y(t) = x(t-2) with the initial condition y(0) = 0. The user applied parameterization and derived the homogeneous solution y_h = Ce^-3t, leading to the particular solution involving the integral v = ∫[e^3T * x(T-2) dT]. However, there is uncertainty regarding the limits of integration, which are currently set from 0 to t. An alternative method suggested is using Laplace transforms, although the user has not yet covered this technique in class.
  • Understanding of first-order differential equations
  • Familiarity with parameterization techniques
  • Knowledge of Laplace transforms
  • Basic integration skills
  • Study the application of Laplace transforms for solving differential equations
  • Learn about the method of integrating factors in first-order equations
  • Explore the concept of convolution in relation to differential equations
  • Investigate the properties of the exponential function in differential equations
Students and educators in mathematics, particularly those studying differential equations, as well as engineers and scientists applying these concepts in practical scenarios.
magnifik
find the solution for the following equation:
dy(t)/dt + 3y(t) = x(t-2), t > 0 and y(0) = 0
i did it by parameterization but am unsure if it is correct. i need help especially with the limits of integration.
y' + 3y = x(t-2)
yh' = -3yh
yh = Ce^-3t
y(t) = v(t)e^-3t
(ve^-3t)' = v'e^-3t - 3ve^-3t
-3ve^-3t + v'e^-3t = -3ve^-3t + x(t-2)
v' = e^3t * x(t-2)
v = int[e^3t * x(t-2) dt] // int means integral
y(t) = e^-3t * int[e^3T * x(T-2) dT] // T is tau
i'm not sure if that's correct. right now i have the limits of integration set to 0 to t
thanks in advance
One way is to take Laplace transforms. I am assuming here that x(t) is a predefined function
we have not discussed Laplace transforms in class yet. x(t-2) stands alone. no further information is given.
