| New Reply |
Finding how much a 5 cm pad compresses when an egg hits it |
Share Thread | Thread Tools |
| Jan11-11, 10:10 PM | #1 |
A 56.0 g egg falls 120.0 m from rest and hits a 5.00 cm thick foam pad. The egg does not break, but instead compresses the foam pad. It is 6.25 ms from the moment the egg hits the foam ad until all downward motion (falling) is stopped. Assuming there is a constant upward acceleration due to the compressing of the foam pad, how much is the pad compressed? m= 56.0 g; delta y= 12 m; pad= 5.00 cm; delta t= 6.25 ms; a= -9.81 m/s2 2. Relevant equations m1v1,i+m2v2,i=m1v1,f + m2v2,f; KE= 1/2mv2; F(delta t)= delta P I really have no idea what to do in this case, and I need to get this equation done. It's the last one on my set. Please help! |
| Jan11-11, 10:12 PM | #2 |
Recognitions:
You could try using conservation of energy to get the speed of the egg at the moment of impact and then use that to get the acceleration of the egg.
| Jan11-11, 10:29 PM | #3 |
You just made my life so much easier! Thank you!
| Jan11-11, 10:58 PM | #4 |
Recognitions:
| Jan11-11, 11:19 PM | #5 |
Mentor
![]() To the original poster: is it 120.0 m or 12 m? You've written both of these in two different places. The latter gives me an answer that works. The former does not (i.e. the pad will not be thick enough). |
| Jan12-11, 08:56 AM | #6 |
Recognitions:
| New Reply |
| Tags |
| force, kinetic energy, momentum, theorem, time |
| Thread Tools | |
Similar Threads for: Finding how much a 5 cm pad compresses when an egg hits it
| Finding time and speed at which skydiver hits the ground! | Calculus & Beyond Homework | 6 | ||
| Finding speed of an object when it hits the ground, after free fall. | Introductory Physics Homework | 4 | ||
| Finding max height and speed before it hits the ground of a rocket | Introductory Physics Homework | 1 | ||
| Finding the initial velocity of a projectile so that it hits a moving object | Introductory Physics Homework | 4 | ||
| Finding the distance a spring compresses | Introductory Physics Homework | 3 | ||
