| New Reply |
Expansion of a Compressible Gas |
Share Thread | Thread Tools |
| Jan12-11, 12:50 AM | #1 |
Hi,
I'm trying to figure out the pressure exerted by a compressible gas (air) after it has expanded out of a cylinder for a simple conceptual design. I'm pretty sure that it's a simple problem, but I'm a little thickheaded atm. Here is my thinking so far: Due to the compressibility of air, I assume that I cannot use the ideal gas model, hence P1V1=P2V2 (assuming an isothermic expansion) cannot be used. Instead, factoring in for compressibility, I get: P1V1Z1=P2V2Z2 (again assuming isothermic expansion) I know the cylinder used and expansion chamber and so I know P1, V1 and V2 and can calculate Z1. This leaves me with two unknowns - P2 and Z2 - but only one equation. How do I get the second equation to solve this? |
| Jan12-11, 07:16 AM | #2 |
Recognitions:
AM |
| Jan27-11, 02:54 AM | #3 |
Z is a compressibility factor. It is used to account for a gases behavior when it deviates from the ideal gas model (which uses a Z of unity). Essentially, no gas has a Z of exactly 1, but gases such as air come close enough to so as to be approximated as 1.
You were right, however. I was addle-brained at that time and for some reason I visualized the air acting as a liquid, where pressure changes the volume only slightly (why? I will never know.. *sigh*) and saw Z as the way to compensate for that. The solution was simply to assume air as an ideal gas and us the normal ideal gas equation. Thanks for replying before and apologies for the late reply and the sub-par question. =) |
| New Reply |
| Tags |
| compressible gas, cylinder, expansion, pneumatic |
| Thread Tools | |
Similar Threads for: Expansion of a Compressible Gas
| Compressible Flow | Calculus & Beyond Homework | 0 | ||
| Is Free Air Compressible? | General Physics | 1 | ||
| Combustion and Compressible Flow | Mechanical Engineering | 5 | ||
| compressible or imcompressible? | General Engineering | 5 | ||
| compressible methane flows | Mechanical Engineering | 1 | ||
