New Reply
Simple Question on Earth Rotation involving Newton III
Share Thread Thread Tools
Jan14-11, 02:09 PM   #1
Simple question with a simple answer, just want a little more description.
Newton III states: For every action there is an equal and opposite reaction.
As the earth rotates one way, what's the opposite force that keeps it "balanced"? Inertia?
Arrived at the question when was thinking about a pendulum in SHM but could not
figure out why if, in a perfect system, why it kept coming back to the same position with the earth rotating only one way? Rationally thought there would be an over swing in the direction the earth was rotating. But Newton III states there must be a force acting on opposite end and after much thought, still stumped.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Jan14-11, 02:13 PM   #2
No force is needed to keep the earth rotating (remember Newton's 1st law) if you wanted to change the rotation then you would need something for the force to act against
Jan14-11, 02:15 PM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
If an object is moving in a straight line at a constant velocity, what's the force that keeps it balanced?
It takes a force to change an object's motion. Regardless of whether it's moving in a straight line or rotating, momentum keeps it moving at the same rate, while a force changes that motion.
Just as you have conservation of linear momentum, you also have conservation of angular momentum.
Jan14-11, 02:18 PM   #4
Assume the earth is rotating left. Now, when watching a pendulum, swing left and right, shouldn't it swing farther left because the sum of all its forces, including the earth's rotation would be greater that way than the sum of all its forces in the right direction because the earth's rotation is missing in the equation?
Thanks for that response BobG. You posted when I was in the middle of writing this.
Jan14-11, 02:19 PM   #5
Mentor
Quote by Jaygo333 View Post
Newton III applies to forces.
Rotation is not a force.
For a pendulum swinging back and forth, there are forces involved and thus Newton III applies. The result is that as the pendulum bob moves to the left of equilibrium, the support (and attached earth) moves ever so slightly to the right of equilibrium.
New Reply
Thread Tools
Similar Threads for: Simple Question on Earth Rotation involving Newton III
Thread Forum Replies
Newton's 2nd Law - Rotation, Torque, Disk Introductory Physics Homework 2
Rotation of earth and weight of an object on the earth Classical Physics 8
Weird second law of newton for rotation Classical Physics 5
Simple question involving steam tables Advanced Physics Homework 3
Simple Rotation + Angular Velocity Question Introductory Physics Homework 1
