Solving Curve C Tangent P: (-3,-2,2)
  • Thread starter Thread starter tifa8
    Curve Tangent
The problem involves finding a unique point P on a parametric curve C defined by the equations (x,y,z)=(3−3t,1−t²,t+2t³), such that the tangent line at P passes through the point (−3,−2,2).
  • Participants discuss the parametric equations of the curve and the direction vector of the tangent line. There is an exploration of expressing the tangent line's parametric equations in terms of a parameter s and attempts to equate these with the curve's equations. Questions arise regarding the understanding of linear interpolation and equations of lines in higher dimensions.
Some participants have provided guidance on expressing the relationship between the tangent vector and the vector from point P to the point (−3,−2,2). The discussion has progressed with one participant successfully finding a value for t, indicating a productive direction in the exploration of the problem.
One participant notes that they have not yet covered linear interpolation or equations of lines in more than three dimensions, which may impact their understanding of the problem.
tifa8
Hello, I need help for this problem
There exist a curve C such that its parametric equation is (x,y,z)=(3−3t,1−t[tex]^{2}[/tex],t+2t[tex]^{3}[/tex]). There is a unique point P on the curve with the property that the tangent line at P passes through the point (−3,−2,2). Find the coordinates of P.
(C) : (x,y,z)=(3−3t,1−t[tex]^{2}[/tex],t+2t[tex]^{3}[/tex])
Attempt to solve it
(x',y'z')= (-3,-2t,1+6t[tex]^{2}[/tex] )
since the above is the direction vector of the tangent T then I tried to express the parametric equation of the tangent in function of t which has given me
x=-3s-3
y=-2ts-2
z=(1+6t[tex]^{2}[/tex])s+2
after that I tried to solve xp=x by replacing x in the line equation by the curve equation but I can't solve that ! I really don't know how to approach this exercise ...
Thank you for your help
Attempt to solve it
x=-3s-3
y=-2ts-2
Hey there tifa and welcome to the forums.
Have you ever studied or covered linear interpolation? Or have you covered the equation of a line in n dimensions (or just 3)?
thank you !
No I didn't cover yet linear interpolation but I think we will see it next week. And no didn't see equations of lines in more than 3 dimensions. What I'm covering now is curves and motion in curves.
What you know is that the difference (3−3t,1-t^2,t+2t^3)-(−3,−2,2) is parallel to your derivative direction (-3,-2t,1+6t^2). Two vectors A and B are parallel if A=k*B for some k. Can you write down an equation expressing that and solve for t?
thank you ! I found t=3 which was correct :)
