Register to reply
Derivation of second order system transfer function
by ryan88
Tags: derivation, function, order, transfer
Share this thread:
ryan88
#1
Jan17-11, 11:02 AM
P: 39
Hi,
I am trying to derive the general transfer function for a second order dynamic system, shown below:
[tex]\frac{Y(s)}{X(s)}=\frac{K\omega_n^2}{s^2+2\zeta\omega_ns+\omega_n^2}[/tex]
In order to do this I am considering a mass-spring-damper system, with an input force of f(t) that satisfies the following second-order differential equation:
[tex]m\frac{d^2y}{\dt^2}+c\frac{dy}{dt}+ky=f(t)[/tex]
Using the following two relationships:
[tex]c=2\zeta\omega_nm[/tex]
[tex]\frac{k}{m}=\omega_n^2[/tex]
I get this:
[tex]\frac{d^2y}{dt^2}+2\zeta\omega_n\frac{dy}{dt}+\omega_n^2y=\frac{f(t)}{m }[/tex]
[tex]\mathcal{L}\left\{\frac{d^2y}{dt^2}\right\}+2\zeta\omega_n\mathcal{L}\l eft\{\frac{dy}{dt}\right\}+\omega_n\mathcal{L}\left\{y\right\}=\frac{1} {m}\mathcal{L}\left\{f(t)\right\}[/tex]
[tex]Y(s)\left[s^2+2\zeta\omega_ns+\omega_n^2\right]=\frac{F(s)}{m}[/tex]
[tex]\frac{Y(s)}{F(s)}=\frac{1}{m(s^2+2\zeta\omega_ns+\omega_n^2)}[/tex]
Wheras my lecturer has the following in his notes:
[tex]\frac{d^2y}{dt^2}+2\zeta\omega_n\frac{dy}{dt}+\omega_n^2y=K\omega_n^2x( t)[/tex]
[tex]\mathcal{L}\left\{\frac{d^2y}{dt^2}\right\}+2\zeta\omega_n\mathcal{L}\l eft\{\frac{dy}{dt}\right\}+\omega_n\mathcal{L}\left\{y\right\}=K\omega_ n^2\mathcal{L}\{x(t)\}[/tex]
[tex]Y(s)\left[s^2+2\zeta\omega_ns+\omega_n^2\right]=K\omega_n^2X(s)[/tex]
This obvisously gives the correct transfer function. So, from the two approaches, I have come to the conclusion that:
[tex]\frac{f(t)}{m}=K\omega_n^2x(t)[/tex]
But I do not understand the physical reasoning behind this. Can anyone offer any help with this?
Thanks,
Ryan
Phys.Org News Partner Engineering news on Phys.org
Comfortable climate indoors with porous glass
Crash-testing rivets
Customized surface inspection
viscousflow
#2
Jan17-11, 06:13 PM
P: 273
That is standard notation. The "trick" is to multiply the right hand side by [tex]\frac{k}{k}[/tex]. As for physical intuition. Perform a unit analysis. You should be able to draw a clear conclusion from that.
ryan88
#3
Jan17-11, 06:48 PM
P: 39
Ah yes, I completely missed that. Although substituting [tex]\frac{k}{m}=\omega_n^2[/tex] leaves the gain of the system as [tex]\frac{1}{k}[/tex] which is then not dimensionless. I thought this transfer function was supposed to be dimensionless?
viscousflow
#4
Jan17-11, 08:30 PM
P: 273
No transfer functions are hardly dimensionless. Transfer functions are the ratio of system [tex]\frac{output}{input}[/tex]. Thus you can see that the transfer function can hold any units as long as it contains the output-input relationship you are looking for.
ryan88
#5
Jan18-11, 02:33 AM
P: 39
Ok, thanks for your help viscousflow. It is very much appreciated.
Ryan
Register to reply
Related Discussions
Transfer function derivation Engineering, Comp Sci, & Technology Homework 1
Help with deriving transfer function of a second order control system Engineering, Comp Sci, & Technology Homework 1
2nd order filter transfer function normalization Electrical Engineering 2
Find transfer function of LP first order Bessel Filter Engineering, Comp Sci, & Technology Homework 0
The transfer function of a delayed system x(t-T) Calculus & Beyond Homework 3
