Calculating Wavelength of Emitted Radiation in Carbon Monoxide Molecule
  • Thread starter Thread starter v_pino
    Molecules
The discussion focuses on calculating the wavelength of emitted radiation when a carbon monoxide (CO) molecule transitions from the first excited rotational state (l=1) to the ground state (l=0). The moment of inertia (I) for the CO molecule is given as 2.23 x 10^-46 kgm². The energy difference between these states is calculated using the formula E = l(l+1)h_bar² / 2I, leading to the correct wavelength of emitted radiation being 2.6 mm. The calculations involve fundamental constants such as Planck's constant and the speed of light.
  • Understanding of quantum mechanics, specifically rotational states.
  • Familiarity with the concept of moment of inertia in molecular physics.
  • Knowledge of Planck's constant and its application in energy calculations.
  • Basic proficiency in using the energy-wavelength relationship in electromagnetic radiation.
  • Study the derivation and application of the moment of inertia in diatomic molecules.
  • Learn about the quantum mechanical treatment of rotational states in molecules.
  • Explore the relationship between energy levels and emitted radiation wavelengths in quantum systems.
  • Investigate the use of Planck's constant in various physical equations and its implications in spectroscopy.
Students and professionals in physics, particularly those focusing on molecular spectroscopy, quantum mechanics, and rotational dynamics of diatomic molecules.
v_pino
The molecular bond between the carbon and oxygen atoms in the diatomic carbon monoxide molecule can be treated as a spring with elastic constant k. The carbon atom has a mass of 12 amu and the oxygen atom has a mass of 16 amu, and the average separation of the two nuclei in the carbon monoxide molecule is 1.4x10^-10m.
A carbon monoxide molecule makes a transition from the first excited rotational state to the ground state. What is the wavelength of the emitted radiation?
E = l(l+1)h_bar^2 / 2I
E = energy
l = quantum number
h_bar = Plancks constant / 2*pi
I = moment of inertia
E = hc/lambda
h = placks constant
c = speed of light in vacuum
lambda = wavelength
I calculated the moment of inertia I in a previous part of the question and it is correct.
I = 2.23 x 10^-46 kgm^2
I assumed that ground state means that l=0 and first excited state means that l=1. I calculated the energy difference between these two states. Then calculated the debroglie wavelength. But I didn't get the correct answer.
Correct answer should be : 2.6 mm
yes, l=0 is the ground state & l=1 is the excited state.
  • · Replies 20 ·
