Cup of hot tea, and I need it just *warm*
  • Context: Undergrad
  • Thread starter Thread starter Cantstandit
    Hot
The discussion centers on calculating the cooling time of a cup of tea from 100°C to 40°C using heat transfer equations. The user references Newton's Law of Cooling, represented by the differential equation dT/dt(t) = -b[T(t) - T_a], where b is a constant, T(t) is the temperature at time t, and T_a is the ambient temperature. An iterative algorithm approach is proposed for calculating instantaneous heat flux, although a non-iterative solution is sought. The user also mentions neglecting evaporation effects by assuming a closed mug.
  • Understanding of Newton's Law of Cooling
  • Familiarity with differential equations
  • Basic knowledge of heat transfer principles
  • Experience with iterative algorithms
  • Research Newton's Law of Cooling in detail
  • Study methods for solving differential equations
  • Explore heat transfer concepts in closed systems
  • Learn about numerical methods for iterative calculations
Individuals interested in thermodynamics, engineers working on heat transfer problems, and anyone looking to understand the cooling process of liquids in closed containers.
Cantstandit
Hello,
Say I don't like to drink hot tea, in fact I don't like to drink anything hot. It is beyond my comprehension why anyone would want to drink something above 40C ;)
I have cup of hot tea 100C and i want to know how long will it take to cool down to 40C.
[tex]\frac{\Delta Q}{\Delta t}[/tex] = -k A [tex]\frac{\Delta T}{\Delta x}[/tex]
(for some reason I can't get the equation to display correctly)
so i have k of course, "delta x" would be the thickness of the mug wall, A is also given . The "delta T" part is the difference between tea and air temperature, i guess?
Now my approach would be to write an iterative algorithm, that will calculate the "instantaneous" heat flux, then lower the temperature a bit and advance time, then calculate heat flux again. Unless there is some other equation which will let me calculate it in a non-iterative way?
It seems silly that I have to iterate just to get an answer to such simple question...
This is of course if I neglect the evaporation effect, say the mug is closed, it is a fancy mug.
Science news on Phys.org
In the limit of infinitesimal time steps time, your equation can probably be rewritten as a differential equation for the temperature like this:
[tex]\frac{dT}{dt}(t) = -b[T(t) - T_a][/tex]
where [tex]b[/tex] is some constant related to your [tex]a[/tex], [tex]k[/tex] and [tex]\Delta X[/tex], and [tex]T_a[/tex] is the ambient air temperature around the cup (assumed constant), you can integrate it to get
[tex]T(t) = [T(0) - T_a] \exp(-bt) + T_a[/tex]
Which tells your the temperature at any time. [tex]T(0)[/tex] is the tea temperature at time 0.
  • · Replies 19 ·
  • · Replies 20 ·
