A question about water and wood.
  • Thread starter Thread starter Gara
    Water Wood
The discussion revolves around a passage from the Discworld book "Going Postal" that suggests a ship may sink to a depth in the ocean where the water's viscosity stops its fall. Participants explore the scientific validity of this idea, focusing on concepts of density, viscosity, and buoyancy in water compared to air.
  • One participant questions the validity of describing water as a "wetter form of air," suggesting it is a bizarre characterization.
  • Another participant clarifies that viscosity and density are distinct properties, noting that viscosity does not significantly increase with water pressure.
  • Concerns are raised about the compressibility of water, with a participant stating that while water density increases with pressure, it does not reach extreme levels.
  • A participant shares personal experience with scuba diving, explaining how buoyancy changes with depth, which may relate to the original question about sinking.
  • It is noted that in reality, water is not very compressible, unlike air, which affects how density changes with depth.
  • Participants discuss that viscosity affects sinking speed but does not determine the depth at which one stops sinking, which is instead related to neutral buoyancy.
Participants express differing views on the interpretation of the passage from the book, with some finding it interesting and others dismissing it as unrealistic. There is no consensus on the scientific implications of the ideas presented.
The discussion highlights limitations in understanding the relationship between viscosity and buoyancy, as well as the compressibility of water, without resolving these complexities.
Gara
Okay so this morning I picked up a very brand new copy of the Discworld book, "Going Postal".
http://homepage.ntlworld.com/ak_gara/Lookie.jpg
Here is a little snippit from the first page.
[snip]It runs: the sea is, after all, in many respects only a wetter form of air. And it is known that air is denser the lower you go and lighter the higher you fly. As a storm-tossed ship founders and sinks, therefore, it must reach a depth where the water below is just viscous enough to stop it's fall.[/snip]
My question is, is this even possible, if yes, why, if no, why?
I'm guessing it's just being used for the story and is not true.
There are a couple of problems with that:
The description of water as wetter form of air is a bit bizarre in this context.
The passage indicates viscous rather than dense. Viscosity is something different than density, it has to do with the amount of friction the boat has with the water, and doesn't appreciably increase with water pressure.
Moreover, the compressibility of water is limited. Just because the density of water increases as pressure increases, does not mean that the density of water ever reaches 2.
Well that's that asnwered :) thanks.
Question acually seems rather silly now that I think about it.
Anyway to lock this topic?
No need to lock the topic, its an interesting one and a perfectly reasonable question. I just took up scuba diving and buoyancy is a bit counterintuitive: your buoyancy decreases the lower you go due to your body and buoyancy compensator (an inflatable life vest, essentially) being compressed. So you actually sink faster the lower you go.
Yes - water is not very compressible, unlike air, so water doesn't get appreciably denser as you go deeper. Air, on the other hand, is compressible, so air does get denser as one changes altitude.
Of course that's how it works in our world (reality), Discworld is a bit different, being supported on the backs of four elephants on a giant turtle and all :-)
Going back to the real world, viscosity doesn't have much to do with the issue - viscosity would affect how fast one sunk (think of it like friction), but would not change the point at which one stopped sinking. One would only stop sinking at neutral buoyancy, which would be a function of the density of the water and not its viscosity.
13K
  • · Replies 18 ·
26K
9K
