New Reply
A bus strip usually contains two columns
Share Thread Thread Tools
Jan21-11, 12:22 AM   #1
What does the term "ground" mean in an ELECTRONIC circuit?
A bus strip usually contains two columns: one for GROUND and one for a supply voltage. What does ground mean in this context and how do we ground a circuit while using a breadboard?
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Company pioneering new types of material for 3-D printer 'ink'
>> Student-built innovations to help improve and save lives
>> Researchers use light projector and single-pixel detectors to create 3-D images
Jan21-11, 12:46 AM   #2
Quote by Pranav Jha View Post
Ground in this case is the return path of the current.
Do you know you ask one of the most difficult question in electronics. The one issue that cause a big percentage of the problems. I truely do not know where to even start. I sure hope professors in school can put more emphysis on grounding. BECAUSE if you truely master grounding, most other circuits are pretty easy. As speed of circuits go up, this become more and more important issue. They even have a special kind of engineer called "Signal Integrity" engineer that do nothing but working on this very issue.
If you want to have your question answer, draw out the schematic and we talk grounding. Look at this thread:
http://www.physicsforums.com/showthread.php?t=464271
This touch the surface of current return ( or you want to call it grounding or whatever). Just touching the surface!!! I am being very long winded because it is that important.
New Reply
Thread Tools
Similar Threads for: A bus strip usually contains two columns
Thread Forum Replies
term "ground" mean in an ELECTRONIC circuit? General Physics 3
Does the ground have to be on X2? Electrical Engineering 1
Fireworks on the Ground General Discussion 11
Math from the Ground Up General Math 14
What will hit the ground first? General Physics 16
