What is role of mass participating factor while doing Modal Analysis?
The discussion focuses on the role of mass participation factors in modal analysis, specifically how they influence the determination of the number of modes required for effective analysis. Participants explore the implications of these factors in understanding dynamic responses of structures.
  • Some participants inquire about the role of mass participation factors in modal analysis and how to determine the necessary number of modes.
  • One participant suggests that the number of modes required depends on the number of degrees of freedom in the system.
  • Another participant explains that modal analysis helps identify which modes contribute to a structure's dynamic response, emphasizing the importance of mass participation factors in this context.
  • It is proposed that all modes within the frequency range of interest should be included, with a recommendation to consider modes up to 2x or 3x the highest frequency of interest, particularly when modes have closely spaced frequencies.
  • A participant notes that the total number of degrees of freedom is not directly relevant to the number of modes used, as modal models can achieve good accuracy with fewer modes once mode shapes and frequencies are established.
Participants express varying views on the relationship between the number of modes and degrees of freedom, with some suggesting a direct correlation while others emphasize the independence of these factors in practice. The discussion remains unresolved regarding the optimal approach to determining the number of modes needed.
Participants do not fully explore the assumptions underlying their claims, such as the specific conditions under which the proposed methods are applicable or the implications of closely spaced frequencies on modal analysis outcomes.
This discussion may be useful for engineers and researchers involved in structural dynamics, modal analysis, and those seeking to understand the implications of mass participation factors in their analyses.
anoopsrikanth
What is role of mass participating factor while doing Modal Analysis and how can we come to a conclusion that how many number of modes are required for a particular Modal Analysis.
Please help me .
Please help me .
Number of modes depends on number of degrees of freedom.
One use of modal analysis is to understand which modes of a structure are causing a particular dynamic response. Mass participation factors are one way to measure which modes are important and which are not.
You need all the modes in the frequency range that you are interested in, plus a safety margin. Including modes up to 2x or 3x the highest frequency you want to study is often a reasonable choice. If you have many modes with closely spaced frequencies, you need to be careful about this - for example run the model with different numbers of modes and check the results are similar.
The total number of degrees of freedom in the model (or the real-world structure) is irrelevant. The number of modes used is often much smaller. One of the advantages of modal models is that they can give good accuracy with a small model size, once you have found the mode shapes and frequencies (and that only needs to be done once).
Thanks
what is g-load analysis doing a chassies g-load analysis for condition lcf 5g-x,5g-z and 4g-y help me what actually it means.
possiblly with somw simple example
I need the MATLAB code for modal analysis of a MDOF system.please help me
23K
