Linear Equation: Definition & Meaning
  • Context: High School
  • Thread starter Thread starter Maxwell
The discussion centers around the definition and meaning of linear equations, particularly in the context of linear differential equations. Participants explore the characteristics of linear equations, their forms, and the implications of linearity in differential equations.
  • One participant defines a linear equation as a straight line represented by the equation y=mx+b, where m is the slope and b is the y-intercept.
  • Another participant suggests that a linear differential equation might be a polynomial of the second degree, based on the derivative of a quadratic function.
  • A different participant clarifies that a linear differential equation involves a function and its derivatives, emphasizing that it must be linear in the dependent variable but not necessarily in the independent variable.
  • One participant provides the general form of a linear first-order differential equation and illustrates it with an example, noting that the solution is not a second-degree polynomial.
  • Another participant discusses the property of linearity in differential equations, stating that linear combinations of solutions yield new solutions, contrasting this with non-linear functions.
Participants express differing views on the definition of linear differential equations, with some asserting that they can be polynomials of the second degree while others clarify that they must adhere to specific linear forms. The discussion remains unresolved regarding the precise definition and characteristics of linear differential equations.
There are limitations in the definitions provided, particularly regarding the assumptions about the forms of linear differential equations and the implications of linearity. The discussion also highlights the need for clarity in the definitions used by participants.
Maxwell
What does it mean if an equation is linear?
Like what is a linear differential equation?
A linear equation is a straight line where m is defined. (m is the slope)
It is in the form y=mx+b, where m is the slope and b is the y-intercept.
This second part is a guess.
A linear differential equation I "THINK" is a polynomial to the second degree.
I think this because the derivative of:
[tex]y=Nx^2+Mx+W[/tex]
is
[tex]\frac{dy}{dx}=2Nx+M[/tex]
...which is linear.
2N is the slope of the derivative and M is the y-intercept.
No.
Remember that a differential equation is an equation that contains a function y and one or more of its derivatives. The equation need only be linear in y, but not necessarily in the independent variable (x). The general form of a linear first-order differential equation is:
[tex]\frac{dy}{dx} + p(x)y = g(x)[/tex]
Where [itex]p(x) \ \ \text{and} \ \ g(x)[/itex] are functions of x. So if I write:
[tex]\frac{dy}{dx} + (\cos{x})y = e^x[/tex]
I guarantee you that the solution is not a second-degree polynomial in x! I seem to remember there being a great tutorial thread on D.E.'s in that subforum.
Jason, I guess you can think of the equation you wrote as the simplest case of a linear first order d.e., in which p(x) = 0. So we're left with:
[tex]\frac{dy}{dx} = g(x)[/tex]
The solution can be found simply by integrating in this case. Not so simple with the previous example.
The crucial point about a "linear differential equation", indeed about "linear" problems in general, is that we can combine two solutions to make a third solution.
If y1 and y2 both satisfy the equation a(x)y"+ b(x)y'+ c(x)y= 0 then any "linear combination" of them, py1+ qy2, where p and q are numbers, does also:
a(x)(py1+ qy2)"+ b(x)(py1+ qy2)'+ c(x)(py1+ qy2)=
a(x)py1"+ a(x)qy2"+b(x)py1'+ b(x)qy2'+ c(x)py1+ c(x)qy2[/sub=
p(a(x)y1"+ b(x)y1'+ c(x)y1)+ q(a(x)y2"+ b(x)y2'+ c(x)y2=
p(0)+ q(0)= 0.
Similarly, if f(x)= ax, then f(nx+my)= a(nx+my)= n(ax)+ m(ay)= nf(x)+ mf(y).
If, however, f(x)= x2, then f(x+y)= (x+ y)2= x2+ 2xy+ y2. The fact that f is NOT linear means that that term 2xy in which the two solutions x and y "interfere" with one another.
  • · Replies 19 ·
  • · Replies 23 ·
  • · Replies 29 ·
