How to evaluate this function?
  • Thread starter Thread starter robertdeniro
    Function
The discussion revolves around evaluating the function f(x) = (e^x - e^(-√x)) / (e^(√x) - e^(-√x)) and specifically showing that f(0) = 1/2. The subject area includes limits and the application of L'Hôpital's Rule, as well as Taylor expansions.
  • Participants discuss potential issues with signs in the equation and suggest rewriting the function to facilitate evaluation. There are mentions of using L'Hôpital's Rule and Taylor expansion as possible methods to approach the limit as x approaches 0. Some participants express confusion about the application of limits versus actual values.
The discussion is ongoing, with various approaches being explored. Some participants have provided guidance on methods such as L'Hôpital's Rule and Taylor series, while others are questioning the assumptions and definitions presented. There is no explicit consensus yet on the best approach to take.
Participants note that the function is undefined at x = 0, prompting discussions about defining it through its limit. There are indications that some participants are struggling with the complexity of the problem and the implications of the limit process.
robertdeniro
[tex]f(x)=\frac{e^{x}-e^{-\sqrt{x}}}{e^{\sqrt{x}}-e^{-\sqrt{x}}}[/tex]
show f(0)=1/2
I think you have a sign wrong somewhere, otherwise the LHS = 1. But if you can express your equation in the form
[tex]e^{\sqrt{x}} = A e^x[/tex]
you can take a logarithm of both sides to get a more manageble equation to solve.
hey, sorry its fixed now
You added "Show f(0) = 1/2" but you haven't defined f(x).
fixed that too
robertdeniro said:
fixed that too
OK, the image probably didn't reload in my browser.
Have you tried taking the limit as [tex]x\rightarrow 0[/tex]? You should really show some of your work before asking for help.
yes i tried lopital twice, didnt work and it was getting really messy so i stopped
I think it helps to note that you can rewrite
[tex] f(x)=\frac{e^{x+\sqrt{x}}-1}{e^{2\sqrt{x}}-1}.[/tex]
Then you can factor the denominator and you get an expression where you can use L'Hopital on an indeterminant factor.
sorry I am not following
if i break up the denominator i get
[tex] f(x)=\frac{e^{x+\sqrt{x}}-1}{e^{\sqrt{x}}+1 e^{\sqrt{x}}-1}.[/tex]
then what?
Write that as a product of two factors, one of which is well-defined in the limit and the other which is indeterminate. L'Hopital can be applied to the indeterminate factor.
ok i see
but we evaluate its limit going to 0, but not AT 0.
i do not recall a theorem that says limit=actual value
robertdeniro said:
ok i see
If the function is undefined at a point, then we should attempt to define it by it's limit at that point, if such limit exists.
show f(0)=1/2
There are 3 ways you can go about solving this problems:
1. The first way is to use L'Hopital's Rule: Have you studied L'Hopital's Rule yet? The L'Hopital's Rule states that:
If we have:
  • [tex]\lim_{x \rightarrow c} \frac{f(x)}{g(x)}[/tex] is of one of the 2 Indeterminate Forms [tex]\frac{0}{0}[/tex], or [tex]\frac{\infty}{\infty}[/tex].
  • And the limit: [tex]\lim_{x \rightarrow c} \frac{f'(x)}{g'(x)}[/tex] exists.
then [tex]\lim_{x \rightarrow c} \frac{f(x)}{g(x)} = \lim_{x \rightarrow c} \frac{f'(x)}{g'(x)}[/tex]
You can try to apply this rule here to see if you get the desired result. :)
2. The second way is to use Taylor expansion.
[tex]e ^ x = 1 + x + \frac{x ^ 2}{2!} + ...[/tex]
3. The last way, also the most fundamental way is to use the well-known limit:
[tex]\lim_{x \rightarrow 0} \frac{e ^ x - 1}{x} = 1[/tex]
Remember that, this limit is very useful when dealing with problems which ask you to take the limit of exponential function!
It goes like this:
[tex]\lim_{x \rightarrow 0} \frac{e ^ x - e ^ {-\sqrt{x}}}{e ^ {\sqrt{x}} - e ^ {-\sqrt{x}}} = \lim_{x \rightarrow 0} \left( \frac{e ^ {-\sqrt{x}}}{e ^ {-\sqrt{x}}} \times \frac{e ^ {x + \sqrt{x}} - 1}{e ^ {2 \sqrt{x}} - 1} \right)[/tex]
[tex]= \lim_{x \rightarrow 0} \left( \frac{e ^ {x + \sqrt{x}} - 1}{x + \sqrt{x}} \times \frac{2 \sqrt{x}}{e ^ {2 \sqrt{x}} - 1} \times \frac{x + \sqrt{x}}{2 \sqrt{x}} \right) = ...[/tex]
Can you go from here? :)
  • · Replies 105 ·
13K
  • · Replies 31 ·
