Book error, or am i missing something? TRIG piece
  • Thread starter Thread starter rygza
    Book Error Trig
The discussion revolves around a right triangle and the relationships between its sides and angles, specifically focusing on the sine function and its application in trigonometry. Participants are examining a notation issue in a textbook regarding the definitions of the sides of the triangle.
  • Participants discuss the definition of sine in relation to the triangle's sides, questioning whether the notation used in the textbook is correct. There is an exploration of the relationship between the height and the hypotenuse, as well as the implications of the notation.
Some participants express confusion about the notation and its implications, while others clarify that the textbook's interpretation is valid. There is acknowledgment of a misunderstanding that has been resolved through discussion.
There is a noted concern regarding the clarity of the notation used in the textbook, which may lead to misinterpretation of the triangle's dimensions. Participants are working with a visual representation that is not provided in the text.
rygza
In the attached picture there is a right triangle (the right angle is on the right bottom corner). The angle, theta, is on the left-most side. From what i remember, sin (theta) is equal to opposite/hypotenuse. If you can see in the picture, it has written: delta x = h/sin(theta)
so, sin(theta) = h/delta x
isn't this wrong?
The difference between X0 and X1 is delta x, which is the hypotenuse.
h is the height, which is the opposite part of sin(theta)=opposite/hypotenuse
So in this case, sin(theta) = h / delta x. Or to get the hypotenuse, delta x = h / sin(theta). The book is correct.
It is a poor choice of notation to use h in this case, as it is slightly confusing. However, h denotes the vertical height not the hypotenuse (which is delta x).
but wouldn't delta x be the length of the bottom side? and then the hypotenuse would be = sqrt((delta x)^2 + (h)^2)
No, look where X0 and X1 are on the picture. The line between those points is delta x - which is the hypotenuse.
OOH yes now it makes sense :smile: I miss one little thing and it costs me 30minutes lol
THANK YOU!
