| New Reply |
Bonding lead(pb) to Inconel |
Share Thread |
| Jan23-11, 02:36 AM | #1 |
I need to bond lead to Inconel? Is this possible? One method I thought about trying is to bond a second metal to the Inconel then bond the Lead(pb) to that> But what would be the steps fluxs and the like?
| Jan23-11, 03:09 AM | #2 |
Specifically, is that lead or lead-tin solder you with to bond?
| Jan23-11, 07:12 AM | #3 |
Admin
Which type of Inconel is one using? |
| Jan23-11, 05:25 PM | #4 |
The door is 1/2 thick Inconel plate, the final surface is to be Lead(pb) but the intermediate material is not speced. The normal process is to grind a clean surface on the ferrous metal then apply a lead bearing flux, usually a mixture that includes zinc and copper heat till glossy then wipe clean. Then apply lead directly onto the tinned surface. as to what grade of inconel I am clueless except that it was speced for heat and low concentration sulpheric acid and mercury and chlorine. Nasty mix huh. The lead will act as a replaceable wear surface.
I believe it is Inconel 625. |
| Jan24-11, 06:17 AM | #5 |
Admin
What is operating temperature of the interface between Pb and Inconel?
Is the Pb liner thin - e.g., on the order of mm's? |
| Jan24-11, 08:22 AM | #6 |
during application unknown, during operation about 400 F 3 to 5 mm we can apply in liquid form if need be.
| Jan26-11, 01:31 PM | #7 |
http://www.masterbond.com/php_news_r...rfile=su46ht-2
Would a high temp epoxy work for you? If this one is not suitable, perhaps they have another formulation that would work. |
| Feb6-11, 08:54 AM | #8 |
I would really like to do the metallurgical route if at all possible. Even if several steps are involved.
| New Reply |
Similar discussions for: Bonding lead(pb) to Inconel
| Soldering Inconel and ceramics | Materials & Chemical Engineering | 7 | ||
| Recapture Pb (lead) from hydrocerussite (powered white lead) - HOW ? | Materials & Chemical Engineering | 1 | ||
| Inconel 718 and derivatives | Materials & Chemical Engineering | 0 | ||
| anti-Bonding/Bonding Molecular Orbitals | Quantum Physics | 8 | ||
| Lead/Lag compensator - lead and lag time to pole and zero locations | Engineering Systems & Design | 2 | ||
